johndeerezach
is it worth the money to install the rear remotes on the back of the tractor? and how much would they cost anybody?
They are not intended to be used to control anything that needs constant hydraulic flow. They are only intended to be used for monitary movement such as controling a cylinder.
thank you that is pretty pricey for that but i bet it is well worth it for the use of the hydraulics.
True, that's JD's official position. However, when I picked up my tractor after the install, the installing mechanic told me if I wanted to run a log splitter or something similar with its own valve downstream, just tie down the lever, he said it won't hurt anything as long as there is a continuous return flow path for the fluid. I have NOT tried this myself, but have heard others say the same thing. It did make sense to me, though. One of the TBN hydraulics wizards could give the OP a more definitive answer.
Thanks for the good info. I have an occasional need to test a device using a hydraulic motor, and would like to use the hydraulics on my 3032e. Since it's occasional, can I just add quick disconnects to my existing circuit near my loader control valve?
