Rear Remotes - Planning stages, need advice
   / Rear Remotes - Planning stages, need advice #71
Excellent job Number9L
Very well thought out and executed.
You're right about everything being tight where the lines come out of the valve.
I bet you used those hydraulic wrenches a lot.
the only thing that I can see missing is some nylon hose protection.
Hose protection will come. Honestly I forgot to order any, but also wanted to see how the hoses laid together and get an idea of what I'd need.
Would it be best to get one sleeve for each hose or one sleeve to fit several hoses like the FEL came with from Kubota?
Oh, and YES, the wrenches worked out great, actually I'd never have got all the fittings on and tight without them!
   / Rear Remotes - Planning stages, need advice #73
Regarding the hose protection...I'm sure there are a lot of opinions.
Mine would be to mix an match. Put about 12" of single hose covering on each hose coming from the QC mount plate, Then nest all of those hoses into a larger sleeve for the balance of the hose run to the valve.
Again Great Job!
   / Rear Remotes - Planning stages, need advice #74
Holy crap on a cracker, thats quite a stack of couplers ya got there. Your going to need a diagram with little circles and arrows so that you can remember which lever controls what coupler. By the way, I'm going to steal your idea about using bed liner on the floor boards. Thanks for posting the pictures.
Steve
The QCs are plumbed in order of the work sections on the valve and their ports.
So.....QCs from the top down...
WS1A = QC1
WS1B = QC2
WS2A = QC3
WS2B = QC4
WS3A = QC5
WS3B = QC6
The bed liner on the floor boards has been great. Boots grip them good still when wet or muddy, rocks in my boots don't scar them all to crap and the pressure washer makes them look new again.
WS1A = QC1
WS1B = QC2
WS2A = QC3
WS2B = QC4
WS3A = QC5
WS3B = QC6
   / Rear Remotes - Planning stages, need advice #77
What model valve did you end up going with? Prince SV? Was the model numbers you posted a few pages for the 2 & 3 spool valves the ones that were 20 week custom orders?
I've got a L3200 (same exact tractor & engine, only slightly less displacement & HP) & am planning on copying your install almost exactly. I may call around & see if anybody local could custom bend steel lines for a reasonable price & will possibly use different QC connectors. I figure if an **** retentive person documented a build that well when it turned out that nice & it almost exactly matches my needs, why reinvent the wheel.
Anything you would have done different on your build in retrospect?
   / Rear Remotes - Planning stages, need advice #78
I can't speak for number9L and he has not been on the forum for a couple of weeks, but the valve set that he bought ended up with internal leakage and I am pretty sure that it was considered within spec. :eek: So ultimately he has hydraulic cylinders that were leaking down at a pretty good rate. :( So you might want to consider a different brand of valve. :confused3: It's to bad he ended up with those problems, he did do an excellent installation. Hopefully he will come back and get us an update of how things are now.;)
   / Rear Remotes - Planning stages, need advice #79
I'm sitting here doing up a spreadsheet of all the parts he listed, prices. links, etc. I trying to figure out where everything went so I fully understand everything. My biggest problem is trying to figure out what length hoses went where, could only trace a couple labeled ones in the photos.
I'll definitely reconsider the valve. I like the concept of float on the tilt for following the crown when plowing snow & trying to use my top cylinder as the start of a down pressure attachment for a 3pt post hole digger. So I'm not excited about going to the pilot valve on the cylinders as that would put a hurting on both those plans. That might mess up fittings & hose lengths thought. Darn, I may have to actually put some thought & design into this myself instead of just slacking & copying. :laughing: I do agree it was an excellent install. It all looked OEM except for possibly the QC bulkhead.
Think a manual or possibly even electronic on/off valve would make things usable with a sloppy valve?
Still thinking about possibly doing steel lines, at least between the valve set & the bulkhead. I need to call some local shops. In general are steel lines competitive with custom hoses?
Any thoughts about going with 1/4" hose between the TnT cylinders & the QC bulkhead? I'm thinking about using some smaller cheaper QC's for my TnT, then 1/2" ag or flat faced for the 3rd spool.
I'll definitely be giving Mr. Fit Rite a call before ordering stuff. :thumbsup: Anybody can sell a product, and whether it's great or crap, you're bound to run into problems at some point. I'd rather go with somebody who has a good track record of support & stands behind their product. Pretty sure all the posts I've seen around here qualify as good support.
Sorry guys, haven't been on in a while. Traveling for work and then BIG project going on at work right behind that.
Yes, I went with the Prince SV valve - part #'s I listed earlier. I haven't had the chance (or made the time I guess) to check the leak rate on the valve. I've got a strong feeling that it's gonna be within their spec anyway. I just can't see all 3 work sections being "bad".....1 maybe, but not all 3. I AM going to do the test so I know for myself - and I probably have already past Surplus Center's return window.....:irked:
Anything to do over, YES....wish I knew that valves had an internal leak spec and I'd have been asking right off what those specs were when I was researching valves. If I had it to do over, I would not go with the Prince valve.
The valve with the long lead time was a Brand valve. Part #'s were posted earlier as well - for the specific "special order" valve config I wanted. Who knows.....I *may* end up with one on my tractor at some point.....maybe. I've learned to deal with the leak off - but it DOES freaking suck and drives me NUTS when I forget about it for a few (5-10) minutes and the BB slams into the ground while I am operating the tractor over uneven ground.
I've got a crude sketch I did when measuring for the hose lengths. I'll find the pic and post it so you know what lengths go where.
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
2011 Kenworth T800 Water Truck (A54865)
2011 Kenworth T800...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
2012 FREIGHTLINER DURASTAR 4300 M7 SBA 4X2 BUCKET (A51406)
2012 FREIGHTLINER...
