Rebuild hydraulic steering control on your own?
   / Rebuild hydraulic steering control on your own? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
JJ, you may know the answer right off. So me having marginal mechanical skills saw instructions on how to rebuild a wheel motor. Not easy but not that difficult. Doesn't look like it needs any specialized tools or equipment but maybe I am mis reading it. I wonder if it is the same for a steering control? I am very nervous about pulling it apart and bearings falling all over the floor and little pieces going away and nothing lining up and having to use that $6000 press to put it all back together.
   / Rebuild hydraulic steering control on your own? #2
No, I have look at the part manual, but never tore one apart.
   / Rebuild hydraulic steering control on your own? #3
I am not JJ but do you mean reseal or rebuild? We reseal them quite a bit and replace parts when worn. But to actually rebuild/remachine something requires a lot of tooling and measuring tools. It is not a big deal to reseal them but there is a few parts you need to keep track of. Get a exploded view before you tear it apart. Is it a geroter style or piston? CJ
   / Rebuild hydraulic steering control on your own? #5
Need to get a part # and a mfg then we can figure it out.
   / Rebuild hydraulic steering control on your own? #6
Hydraulic motors are not that complicated, but you do need to keep everything very clean. I have
not seen any with loose ball bearings. Thrust bearings and ball bearings mostly seem to be
assemblies.
Here is a new Charlynn motor I bought and opened. I like to do that if it is supplied by a non-dealer
to make sure that it is clean inside. This is the "gearotor" style.
If you need a press for the bearings (I prefer a press to a hammer), then a cheapo HF 20T works fine.
That is what I use.
I do not know what the PT uses to control steering, but CUTs use a rotary valve which I have yet
to service.
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2013 John Deere 450J LT (A47477)
2013 John Deere...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2005 Ford F-750 Flatbed Truck (A55788)
2005 Ford F-750...
