Rebuild hydraulic steering control on your own?
   / Rebuild hydraulic steering control on your own? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
JJ, you may know the answer right off. So me having marginal mechanical skills saw instructions on how to rebuild a wheel motor. Not easy but not that difficult. Doesn't look like it needs any specialized tools or equipment but maybe I am mis reading it. I wonder if it is the same for a steering control? I am very nervous about pulling it apart and bearings falling all over the floor and little pieces going away and nothing lining up and having to use that $6000 press to put it all back together.
   / Rebuild hydraulic steering control on your own? #2
No, I have look at the part manual, but never tore one apart.
   / Rebuild hydraulic steering control on your own? #3
I am not JJ but do you mean reseal or rebuild? We reseal them quite a bit and replace parts when worn. But to actually rebuild/remachine something requires a lot of tooling and measuring tools. It is not a big deal to reseal them but there is a few parts you need to keep track of. Get a exploded view before you tear it apart. Is it a geroter style or piston? CJ
   / Rebuild hydraulic steering control on your own? #5
Need to get a part # and a mfg then we can figure it out.
   / Rebuild hydraulic steering control on your own? #6
Hydraulic motors are not that complicated, but you do need to keep everything very clean. I have
not seen any with loose ball bearings. Thrust bearings and ball bearings mostly seem to be
assemblies.
Here is a new Charlynn motor I bought and opened. I like to do that if it is supplied by a non-dealer
to make sure that it is clean inside. This is the "gearotor" style.
If you need a press for the bearings (I prefer a press to a hammer), then a cheapo HF 20T works fine.
That is what I use.
I do not know what the PT uses to control steering, but CUTs use a rotary valve which I have yet
to service.
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
2017 TAKEUCHI TB240 EXCAVATOR (A52705)
2017 TAKEUCHI...
Peterbilt 377 Semi-Truck (A55302)
Peterbilt 377...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
PALLET OF OUTDOOR SUPPLIES (A54756)
PALLET OF OUTDOOR...
2015 CASE 580N (A47477)
2015 CASE 580N...
