Rebuilding Kohler
   / Rebuilding Kohler
Thanks bill Jackssmallengines just shipped my order so i should be getting the stuff early next week. Cant wait to start!
   / Rebuilding Kohler #12
I have had good luck with the sprey engine cleaners you can get at the auto parts store. The foaming stuff works real well.
   / Rebuilding Kohler
I got my parts today at around 3pm. I cleaned the engine of the grease dirt and paint. Still a little left. Took the cylinder head off and there was a lot of carbon. also saw carbon on one of the valves and like small blobs on the other. Took the crank out and that looked to be ok. The service manual was a lot of help in taking it apart. cant wait to get it running again and put it in my newly painted tractor.
   / Rebuilding Kohler
Paint engine before assembly with everything taped off or after everything is put back together?
   / Rebuilding Kohler
I decided to put it back together before painting it. i spent from 10 am to 4 pm wworking on it. There is a lot of friction when i turn the crank. Is it normal when you rebuild an engine? When i put oil in it and spin the crank a couple times will it loosen up. I know the piston connecting rods are torqued right because i checked them 3 times. did i do something wrong?
   / Rebuilding Kohler #16
Did you put oil on the parts when you put them together? You need to slather them up REAL well.
   / Rebuilding Kohler
i used some oil? should i take it apart again and put more oil on the parts or see how it is when i put iol in the oil pan?
   / Rebuilding Kohler #18
Did you do a "rebuild" or just replace some worn out parts?
Did you get the cylinder checked for out of round and taper and take the proper corrective action if there was a problem? At a minimum did you hone the cylinder walls to aid in the new rings sealing?
Did you check the valve stem and valve guide area for excessive wear and the seat and valve ground or lapped?
Did you do the 50 or so other things that a small engine technician would have done?
If not I wish you luck with your "rebuilt" engine.
Bill
   / Rebuilding Kohler
I didnt know about all that. this sounds real bad now. well i guess ill start over
   / Rebuilding Kohler #20
Go easy Bill, he's justaguy. qwerty, come up on private message and I'll try to help you out.
Bell 1600 Gallon Nurse Trailer (A56438)
Bell 1600 Gallon...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2017 Ford F-550...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2020 Aluma 20' Trailer (A59814)
2020 Aluma 20'...
Komatsu PC220LC Excavator (A59814)
Komatsu PC220LC...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
