sunnyside360
Veteran Member
- Joined
- Aug 8, 2006
- Messages
- 1,561
- Location
- Central PA
- Tractor
- JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
I just installed mine a few minutes ago. Took all of 5 minutes. The instructions in the kit said that it fit an M4700, 4800Su, 4900, 5700, 6800, and so on and so forth. I can list all of the models it fits tomorrow if you want. The kit came with a 4 different bolts (2 lengths) for different transmissions and 2 new bolts to bolt the step to the side of the transmission, the brackets, a u-bolt 4 nuts and 4 lock washers for the u-bolt.
My tractor has a loader with a 1" thick mount, but the step reinforcement bracket worked just fine with that.
Chris
I have a 2004 M8200 cab tractor which I bought new and this is the first I've heard anything about the step reinforcement bracket. Do you or anyone else know if the M8200 tractors need this fix? Thanks.
