Recommend a good quality large size drill bit set
   / Recommend a good quality large size drill bit set
Rob, one thing that hasn't come up in this discussion
https://www.amazon.com/gp/product/B00820M9LS/ref=ppx_yo_dt_b_bia_widget_title_o00_s00?ie=UTF8&psc=1
price has gone up since I bought mine, still worth it if you need to "field drill" holes bigger than about 3/8" - can be used (a bit carefully) in a hand drill. I did manage to break the 5/16" cutter trying to drill 1-1/2" EMT, but individual cutters are also available. also, there are more expensive sets that go larger. Cutting depth is 1/2" or less.
Maybe something to consider til that lottery ticket works :licking: ... Steve
Thanks. That's pretty much what the RotoCut set is. I think they are essentially the same type of tools. I will consider a set if I can find a sale or when I save up and feel like splurging.
Rob
   / Recommend a good quality large size drill bit set #72
If you are coved bored there are some plans floating around where you gut a treadmill and put that variable speed high torque motor on your drill press.
   / Recommend a good quality large size drill bit set #73
If and when any of you purchase sets similar to this I would highly recommend buying EXTRA arbors so that each individual cutter has its own, installed and ready to go.
The cutters are sharp and changing arbors carefully is time consuming
   / Recommend a good quality large size drill bit set #74
Good call Terry; most of the time when I use the small kit it's for a single hole size, but you're right about difficulty of changing. I just ordered a second arbor for mine, thanks for the "prod" :laughing: ... Steve
   / Recommend a good quality large size drill bit set #75
Don't know if they are still in business, New York Twist drill Co. offered a good quality set at a great price. Union drill and Greenfield are pricey, but of the best quality. A few other good made in USA Co. but you get the quality you pay for. Best bang for the buck ended up being New York Twist. I guess I need to look them up and see if they are still in business. Larger than 1/2" yes, but until you get into a #5 Morse taper shank it's still small. 4" spade drill in a radial drill press takes some hp to drive it. But it is expensive and can't be found at a ace hardware store
Chris
   / Recommend a good quality large size drill bit set #76
This video is a very good one on how to sharpen by hand. I find it works pretty well for larger bits, but I can't pull it off on smaller ones. I'd guess my cutoff is around 3/8" give or take. I also have a drill doctor but am not terribly thrilled with it. The hand method seems to turn out a better edge, if you can do it. i do wish he was better focused with the camera, but it still works.
   / Recommend a good quality large size drill bit set #77
   / Recommend a good quality large size drill bit set #78
What is the preferred angle on bits for mild steel? I have some older sets that are 118 degrees and some newer ones at 135 degrees with split points. I've tried both and it's hard to tell the difference. Last week I sharpened a 3/8" at 118 degrees with the drill doctor and it punched right through my work better than a new bit, this week I did another one at 135 with a split point and it came out very well too. It was an older Milwaukee bit that was 118 but I re ground it to 135.
   / Recommend a good quality large size drill bit set #79
I tend to use 135 in the drill press and 118 in a hand motor.
Or sometimes 135 for metal and 118 for wood. 118 won't blow out the back as easily as 135.
   / Recommend a good quality large size drill bit set #80
118 is the standard point. 135 is intended for harder materials like Stainless or tool steels, I am told. But I don't know why it would help more on hard stuff...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
WARREN LIGHT TOWER (A58216)
WARREN LIGHT TOWER...
Craftsman Tool Box on Wheels (A57454)
Craftsman Tool Box...
Unused 12x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 12x20...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
