Recommend a good quality large size drill bit set
   / Recommend a good quality large size drill bit set
Rob, one thing that hasn't come up in this discussion
https://www.amazon.com/gp/product/B00820M9LS/ref=ppx_yo_dt_b_bia_widget_title_o00_s00?ie=UTF8&psc=1
price has gone up since I bought mine, still worth it if you need to "field drill" holes bigger than about 3/8" - can be used (a bit carefully) in a hand drill. I did manage to break the 5/16" cutter trying to drill 1-1/2" EMT, but individual cutters are also available. also, there are more expensive sets that go larger. Cutting depth is 1/2" or less.
Maybe something to consider til that lottery ticket works :licking: ... Steve
Thanks. That's pretty much what the RotoCut set is. I think they are essentially the same type of tools. I will consider a set if I can find a sale or when I save up and feel like splurging.
Rob
   / Recommend a good quality large size drill bit set #72
If you are coved bored there are some plans floating around where you gut a treadmill and put that variable speed high torque motor on your drill press.
   / Recommend a good quality large size drill bit set #73
If and when any of you purchase sets similar to this I would highly recommend buying EXTRA arbors so that each individual cutter has its own, installed and ready to go.
The cutters are sharp and changing arbors carefully is time consuming
   / Recommend a good quality large size drill bit set #74
Good call Terry; most of the time when I use the small kit it's for a single hole size, but you're right about difficulty of changing. I just ordered a second arbor for mine, thanks for the "prod" :laughing: ... Steve
   / Recommend a good quality large size drill bit set #75
Don't know if they are still in business, New York Twist drill Co. offered a good quality set at a great price. Union drill and Greenfield are pricey, but of the best quality. A few other good made in USA Co. but you get the quality you pay for. Best bang for the buck ended up being New York Twist. I guess I need to look them up and see if they are still in business. Larger than 1/2" yes, but until you get into a #5 Morse taper shank it's still small. 4" spade drill in a radial drill press takes some hp to drive it. But it is expensive and can't be found at a ace hardware store
Chris
   / Recommend a good quality large size drill bit set #76
This video is a very good one on how to sharpen by hand. I find it works pretty well for larger bits, but I can't pull it off on smaller ones. I'd guess my cutoff is around 3/8" give or take. I also have a drill doctor but am not terribly thrilled with it. The hand method seems to turn out a better edge, if you can do it. i do wish he was better focused with the camera, but it still works.
   / Recommend a good quality large size drill bit set #77
   / Recommend a good quality large size drill bit set #78
What is the preferred angle on bits for mild steel? I have some older sets that are 118 degrees and some newer ones at 135 degrees with split points. I've tried both and it's hard to tell the difference. Last week I sharpened a 3/8" at 118 degrees with the drill doctor and it punched right through my work better than a new bit, this week I did another one at 135 with a split point and it came out very well too. It was an older Milwaukee bit that was 118 but I re ground it to 135.
   / Recommend a good quality large size drill bit set #79
I tend to use 135 in the drill press and 118 in a hand motor.
Or sometimes 135 for metal and 118 for wood. 118 won't blow out the back as easily as 135.
   / Recommend a good quality large size drill bit set #80
118 is the standard point. 135 is intended for harder materials like Stainless or tool steels, I am told. But I don't know why it would help more on hard stuff...
2014 DORSEY EXPANDABLE FLATBED (A59575)
2014 DORSEY...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
ALLISON TRANSMISSION (A55745)
ALLISON...
13042tx (A55973)
13042tx (A55973)
John Deere 60 Tractor (A59814)
John Deere 60...
Box of 22 Flat Webbing Sling (A57454)
Box of 22 Flat...
