Recommendation, Bolt on Bucket Tooth bar
   / Recommendation, Bolt on Bucket Tooth bar #1
Spike56
Platinum Member
Lexington, Texas
JD 2355
Considering a purchase. Anyone recommend a manufacturer / brand ?
   / Recommendation, Bolt on Bucket Tooth bar #2
I'm happy with my Ratchet Rake. No holes to drill, mounts/dismounts easily, and not fussy about width of bucket lip. (3) Much of my use is to shallow-scratch my long d'way (bottom teeth (y)) before dragging to move fines into potholes. It does a LOT more.
That's a pretty good size tractor that you have so I would recommend these: W.R. Long, Inc. | Tooth Bar & Wear Blades
I have one and it's over kill for my tractor....
I HATE my Ratchet Rake... fine for smoothing and leveling but you can not dig dirt with it.
Thanks, This looks like a good one. I was trying to determine if anyone had one that did not require drilling your bucket. Such as,
Tractor Bucket Toothbar
This one "looks" okay but .... I do not want to purchase and then find out it is not worth it / doesn't work well.
   / Recommendation, Bolt on Bucket Tooth bar #7
I like my Ratchet Rake too, for clearing in woodlands and minor grading and garden prep.
However, you CANNOT DIG with a Ratchet Rake attached to your bucket.
A Deere 2355 weighs 6,000 pounds bare tractor. If you want to dig less wide than your bucket, a Bucket Spade from Bucket Solutions should be considered. There are other Bucket Spades but Bucket Solutions' spade is the heaviest sold and most suitable for your heavy-ish compact tractor.
Thanks Jeff, I was looking for something to dig with. No large areas, but more for say planting a tree / minor landscaping / that sort. Really, just getting a hole started is the usually the hardest part.
Do you have a bucket spade too ? Wondering how well this might dig. Don't want to mess up / bend my tractor bucket.
   / Recommendation, Bolt on Bucket Tooth bar #9
Read the two attached threads in Post #7.
   / Recommendation, Bolt on Bucket Tooth bar #10
I have the Bxpanded Piranha tooth bar , it cuts dirt very good , I leave it on all the time, I can grade , dig and back drag my driveway, the step bit they send wit it worked good, cut easy
Spudnik 30” Self-Propelled Utility Piler (A47369)
Spudnik 30”...
2013 John Deere 824K (A48561)
2013 John Deere...
John Deere 6155R (A48561)
John Deere 6155R...
2007 Ford F-350 Post Puller Service Truck (A45336)
2007 Ford F-350...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A45676)
2017 KENWORTH T680...
2011 International WorkStar 7500 T/A 9.5 CuYd Dump Truck (A45336)
2011 International...
