Recommendation, Bolt on Bucket Tooth bar
   / Recommendation, Bolt on Bucket Tooth bar #1
Spike56
Lexington, Texas
JD 2355
Considering a purchase. Anyone recommend a manufacturer / brand ?
   / Recommendation, Bolt on Bucket Tooth bar #2
I'm happy with my Ratchet Rake. No holes to drill, mounts/dismounts easily, and not fussy about width of bucket lip. (3) Much of my use is to shallow-scratch my long d'way (bottom teeth (y)) before dragging to move fines into potholes. It does a LOT more.
That's a pretty good size tractor that you have so I would recommend these: W.R. Long, Inc. | Tooth Bar & Wear Blades
I have one and it's over kill for my tractor....
I HATE my Ratchet Rake... fine for smoothing and leveling but you can not dig dirt with it.
Thanks, This looks like a good one. I was trying to determine if anyone had one that did not require drilling your bucket. Such as,
Tractor Bucket Toothbar
This one "looks" okay but .... I do not want to purchase and then find out it is not worth it / doesn't work well.
   / Recommendation, Bolt on Bucket Tooth bar #7
I like my Ratchet Rake too, for clearing in woodlands and minor grading and garden prep.
However, you CANNOT DIG with a Ratchet Rake attached to your bucket.
A Deere 2355 weighs 6,000 pounds bare tractor. If you want to dig less wide than your bucket, a Bucket Spade from Bucket Solutions should be considered. There are other Bucket Spades but Bucket Solutions' spade is the heaviest sold and most suitable for your heavy-ish compact tractor.
Thanks Jeff, I was looking for something to dig with. No large areas, but more for say planting a tree / minor landscaping / that sort. Really, just getting a hole started is the usually the hardest part.
Do you have a bucket spade too ? Wondering how well this might dig. Don't want to mess up / bend my tractor bucket.
   / Recommendation, Bolt on Bucket Tooth bar #9
Read the two attached threads in Post #7.
   / Recommendation, Bolt on Bucket Tooth bar #10
I have the Bxpanded Piranha tooth bar , it cuts dirt very good , I leave it on all the time, I can grade , dig and back drag my driveway, the step bit they send wit it worked good, cut easy
KBH Tender (A56438)
KBH Tender (A56438)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
1979 Ford H-48 Excavator (A56438)
1979 Ford H-48...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
