Recommendations on fish for pond
   / Recommendations on fish for pond #21
KY: Kentucky Dept Fish and Wildlife -
"To provide hours of good fishing, a pond must be properly stocked. Many pond owners may try to stock their ponds with locally caught or purchased fish. This practice is highly unadvisable because it usually results in an unbalanced or undesirable fish population. The Kentucky Department of Fish and Wildlife Resources (KDFWR) offers help to those wanting pond management advice and pond stocking service.
KDFWR will supply small fish for new or renovated ponds. The only cost to the pond owner is a small fee to cover transportation costs. Ponds with existing fish populations are not eligible for the program.
The KDFWR has experimented with various fish combinations for pond stocking and has found largemouth bass and bluegill to be the best combination for most Kentucky waters. Channel catfish are also available upon request".
:thumbsup:
Questions and comments:
If the state stocks my pond, do I have to let the public fish it? No, but you are encouraged to let responsible anglers fish after they have obtained permission.
When can I start fishing my newly stocked pond? Usually, there is a 2-3 year waiting period.
What if I stock other species, or additional fish? This will most certainly lead to imbalance in the fish population. This is not recommended. Kentucky's pond stocking program is based on many years of research.
Fish harvest - largemouth bass should not be harvested from the farm pond until they are 14 or 15 inches in length. Then, for every bass harvested, about 40-50 bluegill should be harvested. A maximum of 25-30 pounds of bass should be harvested per year.
   / Recommendations on fish for pond #22
You might consider letting the pond set for a year with nothing but minnows and some crawdads, give them a headstart on the Bass and Bluegill. Whatever you do, don't let anyone dump their unwanted goldfish into the pond, it happened to me, now I have a goldfish farm. Good luck.
   / Recommendations on fish for pond #24
How about a put and take fish like channel cats. They will not breed unless they have some kind of tunnel like habitat like hollow logs, culvert, etc. Stock some baitfish this year and some cats this fall or maybe next spring. If you think you are getting close to catching them all, just get some more. Hybrid stripers can be done the same way.
   / Recommendations on fish for pond #25
If you just let it sit, you can still end up with blue gills. Their eggs apparently travel on birds and such and populate new ponds.
But I would go with the fish wagon - I believe that's what's coming to your town - I use them too. You can buy some fish this year and than every year add more, fish needs time to grow and sooner you start, sooner they will be of decent size.
Thanks again for all the replies.
LostintheWoods - thanks for the link. I had been told, by lots of folks, that fish were available for free, but if you took them then you HAD to open your pond to the public. Apparently, wrong on both counts. The cost is a little cheaper than the fishery price. I'm going to have to investigate on what is required to apply for the "state fish".
   / Recommendations on fish for pond #27
Dont some catfish tunnel into the banks? I would want to avoid those.
   / Recommendations on fish for pond #28
rtimgrey, learn about the effects of "low Dissolved Oxygen". Low D. O. is more of a problem in the hot months. Nothing worse than a pond with upside down floating fish. One of the best things your pond can have is fresh water coming in. I have seen people raise their dam causing less water to flow through the pond and lowering the D.O. It's kind of a trade off because the deeper water will be 15-20F cooler in the summer months. Fish require less D.O. in cooler water, This may not be a problem where you live.
I agree with others, "Big Bird"=bad for ponds.
If you ever need to replace you heating/cooling system and your home is within distance, check out "Closed loop geothermal heatpump". With a pond, it's almost like free energy.
   / Recommendations on fish for pond #30
Yes, the only person that must be allowed to fish there is LostInTheWoods.
:D:laughing:
BTW, one of the KY government services (I think Soil and Water Conservation, maybe?) will send someone out to your site to evaluate pond sites and provide recommendations. Same thing for improving forest lands for timber or wildlife. All no charge.
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
Brent 320 Auger Wagon (A59814)
Brent 320 Auger...
