Removal of Asbestos siding
   / Removal of Asbestos siding #11
I have a property with a 1,300 square foot home on it. Home was built in the late 50's and has asbestos siding. I would like to remove the siding, replace the windows and install hardi plank.
Our area allows the homeowner to remove the asbestos and the local dump will accept it.
Wondering if the removal of the siding is as big a deal as it is made out to be. I will wear the appropriate mask but do I need to suit up and water down the siding?
My thinking is I can just use a nail puller and remove most of the siding without damaging it. Thoughts?
I don't have a good answer for you but I do have my own story to relate. About 30 years ago I bought a house with old siding. At the time I didn't know that some siding contained asbestos but I did no it looked awful and needed replacing. I had the local sanitary service bring me a dumpster and I went ahead and removed the siding (and old roofing) myself and put it all in the dumpster. I did not wear any protection since I didn't know there was any problem. Two days after the service company picked up the dumpster I got a call from a local air quality guy who explained to me that the siding contained asbestos and asking me to come into his office. I went and he explained that the sanitary service company had to shut down the whole recycle center and stop all inbound deliveries while people in hazmat suits separated my asbestos siding from all the garbage. They had to specially double bag all of it (about 3 yards or so total) and take it to a special landfill somewhere down near Seattle. I told him that if I'd known it contained asbestos and that it was such a problem I would have just dug a hole and buried it on my property. He informed that he didn't just hear me say that and - if he had - he was required to report it! Sheesh! Apparently I could have been charged for all the work removing and bagging my siding and for the time the sanitary service company was shut down. Fortunately they didn't do so. Would I do it myself again? No, I wouldn't.
   / Removal of Asbestos siding #12
So I have a question pertaining to the disposal. Is the reason they treat asbestos products different in regards to the disposal primarily due to the possibility of the people at the landfill ingesting it or once disposed, does it do something wrong in the hole in the ground?
   / Removal of Asbestos siding #13
The last I knew an individual could remove asbestos containing material and dispose of it in a landfill with no issues, non-friable asbestos removal and disposal by an individual owner is / was treated completely different then the same removal by a company.
While asbestos is a some what hazardous material to handle it is not coiled up and waiting to spring out and grab you the only hazard is breaking up the material and releasing the small fibers in the air.
I was qualified back in the 90"s to contain and remove asbestos, I can't count the number of classes and training I had to go thru because I worked on or near equipment that had the possibility of having asbestos containing material in or on it.
Also almost all of the time asbestos containing material is quite safe to be around until it is disturbed.
   / Removal of Asbestos siding #14
Thoughts?
My thoughts are the some of the responders didn't read that line.
The stuff won't whack you down like a King Cobra or mixing bleach and ammonia. You're outside with plenty of ventilation. Just don't break it up into small pieces or use a saw if you can avoid it.
   / Removal of Asbestos siding #15
Yep, do it right and protect yourself from the dust on what you take down and put up. Now, you can use more friendly methods than sawing when it comes to Hardi. By me, I can't take freaking drywall to the dump with a rolled texture on it w/o having a lab test it. Really.
The texture coating frequently has asbestos in it. Asbestos is bad , really bad if you smoke. Remove it properly
   / Removal of Asbestos siding #16
I've been in the Environmental Health field for 25+ years. My advice - either leave it alone or have it removed by professionals.
Now there is a footnote to this - no forget the footnote.
   / Removal of Asbestos siding #17
People have gotten stupid almost to the point of hysteria with regards to asbestos, much like they have with PCBs. If it was a bad as some claim, every person who has worked in the asbestos industry would be dead. Think about it...very few if any used masks back then during the hayday of asbestos production and we (yes, a full year working in an asbestos mill at Clinton Creek, Yukon) breathed in HUGE quantities of asbestos dust. There used to be over 2500 different uses for asbestos so everybody was exposed to great quantities. People should have been dropping like flies...but they didn't.
It's commonly said that there is no safe level of exposure to asbestos but do not conflate that with meaning a very small exposure will definitely cause cancers in everybody. It has caused cancer in some people but seriously, how many products do cause cancer and are still sold in great quantities?
I just wish the same standards were applied equally to everything.
As a bit of FYI... The 116 things that can give you cancer the full list | Society | The Guardian
   / Removal of Asbestos siding #18
Dare i say it? The only danger from asbestos is inhaling large quantities of the dust fibers. People and laws have over reacted to the danger.
   / Removal of Asbestos siding #19
I think some of the most hazardous occupations were ship building, boiler work and automotive brakes where it was often used in its non-bound form and then it was repeated exposure over a long period of time. Same hysteria can be said of lead in plumbing where I have to wonder how much of a soldered joint ever enters the water flow. MIL's toilet shut off valve (compression fitting) failed recently because the valve maker can no longer use lead and the compression caused the valve body to crack. The plumber said there have been cases where the valve has actually shot-off the stub and flooded buildings.
   / Removal of Asbestos siding #20
For many many years, Every HS chemistry class used asbestos mats to put hot items on.
2001 Chevrolet Silverado 1500 4x4 Flatbed Truck (A44571)
2001 Chevrolet...
2015 Ford F-450 Knapheide Service Truck (A44571)
2015 Ford F-450...
2025 AllMetal K0720 UNUSED 20 ft. Bi-Parting Metal (A47484)
2025 AllMetal...
2025 Wolverine TF1-66-4000G Adjustable Pallet Fork (A47484)
2025 Wolverine...
AGT Mini Excavator QNT50R (A47809)
AGT Mini Excavator...
Massey Ferguson 431 (A46443)
Massey Ferguson...
