Removing JD 540 loader Joystick mechanism to replace broken valve controllers
   / Removing JD 540 loader Joystick mechanism to replace broken valve controllers
mine was a different part but had two snap rings and nuts twisted opposite.
   / Removing JD 540 loader Joystick mechanism to replace broken valve controllers #22
Thanks the advice!
From your pictures my unit looks the same as yours. Can't tell if the parts are for a 540 or what, since the loader is actually a BushHog 2445QT, but the CV assembly appears to be the same.
My question is, I know there is 1 snap ring on each piston, just behind the larger 19mm nut, which I removed with an awl. Is the other snap ring in the same location or a different one? Are 2 nuts the ones in the pictures?
Since you replaced the whole Joystick Assembly, where do you disconnect it? Is the same removal procedure required to remove the whole joystick assembly?
I appreciate your help!
   / Removing JD 540 loader Joystick mechanism to replace broken valve controllers #23
The cables disconnect by holding the larger nut with a wrench and then back off the smaller nut with a second wrench.
HarmonyFarm, jd110 is correct. Nuts spin off in opposite direction to each other. Then the whole black unit comes off for replacement
1995 Ford F800 Dump Truck, VIN # 3FEXF80C7SJA06733 (A48836)
1995 Ford F800...
Brouwer Hitch-Hiker 3600-R Piggyback Forklift (A49346)
Brouwer...
2020 CATERPILLAR 259D3 SKID STEER (A50458)
2020 CATERPILLAR...
4 Yard Commercial Dumpster (A49346)
4 Yard Commercial...
(1) 10ft Tarter Livestock Panel (A48837)
(1) 10ft Tarter...
UNUSED 2025 INDUSTRIAS AMERICA FT510 DUMP TRAILER (A50459)
UNUSED 2025...
