Removing JD 540 loader Joystick mechanism to replace broken valve controllers
   / Removing JD 540 loader Joystick mechanism to replace broken valve controllers
mine was a different part but had two snap rings and nuts twisted opposite.
   / Removing JD 540 loader Joystick mechanism to replace broken valve controllers #22
Thanks the advice!
From your pictures my unit looks the same as yours. Can't tell if the parts are for a 540 or what, since the loader is actually a BushHog 2445QT, but the CV assembly appears to be the same.
My question is, I know there is 1 snap ring on each piston, just behind the larger 19mm nut, which I removed with an awl. Is the other snap ring in the same location or a different one? Are 2 nuts the ones in the pictures?
Since you replaced the whole Joystick Assembly, where do you disconnect it? Is the same removal procedure required to remove the whole joystick assembly?
I appreciate your help!
   / Removing JD 540 loader Joystick mechanism to replace broken valve controllers #23
The cables disconnect by holding the larger nut with a wrench and then back off the smaller nut with a second wrench.
HarmonyFarm, jd110 is correct. Nuts spin off in opposite direction to each other. Then the whole black unit comes off for replacement
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
2015 Chevrolet 3500 Diesel Truck (A50490)
2015 Chevrolet...
1999 JEEP WRANGLER (A50459)
1999 JEEP WRANGLER...
Toro Time Cutter Max Zero Turn (A48837)
Toro Time Cutter...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
2004 Ford F-750 Crew Cab Wrecker Tow Truck (A48081)
2004 Ford F-750...
