Removing JD 540 loader Joystick mechanism to replace broken valve controllers
   / Removing JD 540 loader Joystick mechanism to replace broken valve controllers
mine was a different part but had two snap rings and nuts twisted opposite.
   / Removing JD 540 loader Joystick mechanism to replace broken valve controllers #22
Thanks the advice!
From your pictures my unit looks the same as yours. Can't tell if the parts are for a 540 or what, since the loader is actually a BushHog 2445QT, but the CV assembly appears to be the same.
My question is, I know there is 1 snap ring on each piston, just behind the larger 19mm nut, which I removed with an awl. Is the other snap ring in the same location or a different one? Are 2 nuts the ones in the pictures?
Since you replaced the whole Joystick Assembly, where do you disconnect it? Is the same removal procedure required to remove the whole joystick assembly?
I appreciate your help!
   / Removing JD 540 loader Joystick mechanism to replace broken valve controllers #23
The cables disconnect by holding the larger nut with a wrench and then back off the smaller nut with a second wrench.
HarmonyFarm, jd110 is correct. Nuts spin off in opposite direction to each other. Then the whole black unit comes off for replacement
Flat Bottom Boat w/ Trailer (A48836)
Flat Bottom Boat...
2019 TAKEUCHI TB250-2 EXCAVATOR (A50458)
2019 TAKEUCHI...
2024 CATERPILLAR 265 SKID STEER (A50458)
2024 CATERPILLAR...
UNUSED LANDHONOR 9200# RATCHET & G70 CHAINS (A50460)
UNUSED LANDHONOR...
UNUSED LANDHONOR WEBBING SLING (A50460)
UNUSED LANDHONOR...
New/Unused Quick Attach Pallet Forks (A48837)
New/Unused Quick...
