Removing old fence posts
   / Removing old fence posts
Put a price on them and they will be stolen. Nothing but empty holes the next day.
mark
Not until AFTER I pull them out and stack them up....
I've left few post holes uncovered but, of those few, I've found a small animals trapped in a couple of them so, once you get the post pulled, please consider filling the holes immediately.
Oh yes. We have three Labs that love to run. One leg in a fence post hole and their competition days are over.
   / Removing old fence posts #14
My son was replacing fence for me and he just tilted the bucket down an hooked the fence with the hook that is welded on the top of the bucket and pulled them out with the fence.
My old neighbor puts his bucket pointed about 30 degrees down about a foot from the post, pulls forward and when the bucket hits the post about a foot down tilts the bucket up. kind of messy but he doesn't have to get off the tractor.
I usually pull them out with a nylon strap (choker). The nylon gets a lot better bite on wood than a chain does. I choke it around the post and pull them out with the loader. As someone else said, it goes a lot faster with someone helping, only problem is I always end up being the ground man while wife operates tractor.
   / Removing old fence posts #15
I also do choker chain for old round fence posts. I used that pallet clamp thing when pulling up broken square posts the horses have broken off at ground level.
   / Removing old fence posts #16
One thing I forgot to mention, short-link chain works much better than long-link chain for a choker. Likely you will have to order short-link because they do not normally stock it in most places.
   / Removing old fence posts #17
   / Removing old fence posts #18
I don't know about wood posts. But, I have used my Hi-Lift and an 18" section of chain for T-posts. Just a few pumps of the handle and out they come. B.
   / Removing old fence posts #19
If you want to re-use the posts, you're probably best off with a chain. I keep dreaming of a way to pull the posts without having to get off the tractor and hook the chain to each. One way would be with some sort of hydraulic grabber, maybe a modified bale grabber? Another would be to bolt a V-notched steel plate to the bucket and pull the posts like pulling nails.
Hmmm. I suppose another approach might be to cut them off at ground level, pound the stub down a couple of inches and cover each with a bit of dirt...if the posts are cedar, redwood (hah!) or PT, they'd probably be good for another decade before rotting/sinking down enough to leave much of a depression.
BOB
   / Removing old fence posts #20
How about a 'j hook' attachment similar to this t post puller? I'm sure something could be fabbed up to work. Say, on the end of a boom attachment.. I dont do drawings, so imagination is required :)
UNUSED FUTURE 29" PALLET FORKS W/ MAST (A57193)
UNUSED FUTURE 29"...
Uni-Carriers S1S1L15NV 3,000lb Electric Forklift (A55851)
Uni-Carriers...
JOHN DEERE CS15 BATWING ROTARY MOWER (A57192)
JOHN DEERE CS15...
UNUSED FUTURE SE61-61" HYD SWEEPER (A57193)
UNUSED FUTURE...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
