Removing Wallpaper?
/ Removing Wallpaper? #1
Steelfan
Platinum Member
Central PA
New Holland TC21D
It seems I'm getting all my advise here lately, but the advise is great, so here we go again. Has anyone ever removed wallpaper from their walls. We built our house 14 years ago, and my wife is tired of the wallpaper we put up. Do we need to buy a stripper, or is there another way to remove it? She tried the spray stuff. It didn't work to well. I'd be happy to hear any ideas to save me time, and money in this project. Thanks again TBN members for everything. Kent
/ Removing Wallpaper? #2
We rented one of the commercial strippers and then went out and bought a Wagner. The Wagner works just as well but you have to be a bit more patient on the heat-up times. You probably have sheetrock under your paper - just be carefull not to overdue it and start stripping the paper off of the sheet rock!
Thanks Andy, Yes the biggest concern I have is the sheetrock. I've worried about taking the paper off of the outside of the drywall. We didn't put anything on the walls, but the primer that the builder put on. Thanks for the helpful reply. Any idea of cost for the Wagner? Kent
/ Removing Wallpaper? #4
We just remodelled the kitchen. After much trial and error, I found a good way (boy, that's really an oxymoron - a good way to remove wallpaper) that worked well.
1. First, pray that whomever installed the paper used a good wallpaper primer such as Sheildz. Drink a beer to get in the proper mindset for wallpaper stripping.
2. Get one of the paper scoring tools (~$7) at a wallpaper store. Score the wallpaper four times more than you think you should. Don't push real hard or you'll score the drywall paper also.
3. Soak the wallpaper with one of the enzymatic wallpaper paste stripper solutions, mixed with very hot water.
4. Here's the trick - spread a 1/8" thick layer of premixed drywall compound over the panel you're working on. Let it sit for a half hour. While it is sitting, drink a beer to help prepare you for the fun ahead. Score the next piece you will be removing.
5. Carefully scrape the drywall compound off and put it on the next piece.
6. Use a stiff putty knife to carefully scrape off the old wallpaper. Don't push too hard, or catch a corner of the blade, as you'll gouge the drywall.
7. Using a floodlight, shine the light down the wall so you can see all the small schreds of paper you missed. Those halogen lights work well, but they're pretty hot, so you'll need a beer to cool off.
8. Scrub the wall down with Spic & Span and let it dry. If you will be living in the house long enough that your spouse will want to change the wallpaper again, go over the wallpaper areas with a new coat of Shieldz.
9. Make sure your spouse works with you so they'll think twice about wallpapering a beautiful drywall surface again.
I'm getting the idea, I need a lot of Beer. Is Old Mil Lite OK?My doctor yelling about my drinking habits a bit. I hope my wife reads this, it will be a great reason for a party. LOL Thanks for the reply. I think we got a long road ahead. Kent
/ Removing Wallpaper? #6
Chris,
If I understand your step by step instructions correctly. the key ingredient to proper wallpaper removal is the beer. /w3tcompact/icons/smile.gif
If this is the case, or twelve pack. does any one brand or flavor work better than another. /w3tcompact/icons/laugh.gif
Although my sippin days have mostly subsided, one of my favorites has always been Rolling Rock, but I am willing to experiment with others to see if they provide better assistance in the art of home improvement.
Yeah Mark, I think beer is the main thing. A man's gotta do what a man's gotta do. Kent
/ Removing Wallpaper? #8
If the paper is vinyl just peel the vinyl face off, this will leave the paper backing which can then be soaked and peeled off very easily(provided wallpaper size was used when the paper was installed). If wall size was not used this method will still work but a little elbow grease is needed to push a 6" drywall knife to scrape things down.....it will be a pain no matter what method is used if there is no size under the paper.
/ Removing Wallpaper? #9
The Wagner ran about $60. if I remember correctly. Rental of a professional steamer ran $30 for 4 days. I like to work to my own schedule. Chris had some real good ideas (hmm - will scotch remove really bad wallpaper?) so I think you are off to a good start, though the steamer does what the spackling compound would with less mess.
/ Removing Wallpaper? #10
I agree with everything that has been said so far - especially concerning the beer! However, just one other comment. If you're lucky (and why should you ever think that will be the case /w3tcompact/icons/crazy.gif), and the walls were properly primed then any of the suggestions will work. But if you're not lucky and the walls were not properly prepared, even using all the techniques that have been mentioned may not work without ripping the daylights out of the dry wall. By all means try the removal techiques first, but if they don't work you might be able to paint over the wallpaper. It depends on the kind of wallpaper that is there, and you may (read probably will) see seams and blemishes, but it can be done.
But the best possible way of dealing with wallpaper is to hire someone else to do it /w3tcompact/icons/wink.gif!
/ Removing Wallpaper? #11
<font color=blue>But the best possible way of dealing with wallpaper is to hire someone else to do it !</font color=blue>
And have a beer while you watch!!
mike
/ Removing Wallpaper? #12
Kent, I don’t know a ton about wall paper---never cared for it, although there is some nice stuff out there---are you planning on papering again? If so, I understand, depending on the original paper, if it is still adhering well you can paper over the existing. Then you can just drink the beer, call it a done project and let your wife put new paper up. That would work for me. ./w3tcompact/icons/eyes.gif
MarkV
/ Removing Wallpaper? #13
Kent,
If you can get your wife to drink enough of the beer, maybe she will no longer care what the wallpaper looks like and you won't have to change it at all. THEN, you can take the money saved from not having to buy New wallpaper and put it towards a new tractor implement.
Merely a thought, and if asked, I will Disavow any knowledge of ever having made such a suggestion.
/ Removing Wallpaper? #14
Ain't going to EVER get into that wallpaper thing again! We bought a historic home, and in restoring it, found some walls with as many as 11 layers of wall paper. some of the wood trim had 17 coats of paint! what a chore to get that old critter back into shape! Buy the beer, and hire someone!
/ Removing Wallpaper? #15
better idea, hire a carpenter to put up panelling or bead board...then drink a beer
I'm grateful for all the suggestions. The only thing I'm happy with is the Beer. I can handle that one. I will tell a small story about my wife and wallpaper though. I was off work with a back injury, about 5-6 years ago, and my wife decided to wallpaper our living room. We decided on a 2 foot border at the top with the rest of the wall being another design. Also we bought molding for between, and above the paper. After 3 hours of watching my wife put up 2 of the two foot sections of paper., I decided to take over. I finished the room in about four hours completely. I'm not a pro at this , but I agonized over watching her do it (badly). I think everyone understands my problem. It me or the beer. I'm betting the the beer. Thanks guys. Kent
PS I like the hire a carpenter idea, and the paneling, but my wife would make me remove that after about 5 years.
You're right there. I can never do things the easy way. I'm married for 18 years. LOL. Kent
/ Removing Wallpaper? #19
When we brought this place it had some of the world's ugliest wallpaper. The wallpaper was on the second story of a cathedral ceiling. We set up the ladders and scored the paper. Then we used the paste enzyme. Waited and then scraped. Very slow going and hard work.
My wife got fed up and brought a Wagner steamer for 50 bucks from Walmart. Well the steamer worked great. Much faster than the enzyme. But one BIG caveat. The enzyme actually destroys the glue. The steamer only softens it. So as we scraped the paper fell on the floor, ladders, the dogs, etc. Then it hardened back up and stuck fast. So we created twice as much work.
So use the steamer but be sure and use a dropcloth. Also when finished we washed the walls with enzyme to get rid of all the glue.
Phil
/ Removing Wallpaper? #20
Whoops - wrong pic on above post. This one shows the acclaimed world's ugliest wallpaper.
Phil
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2012 International 4300 Reefer Truck (A63689)
2012 International...
INTERNATIONAL 4900 GRAIN TRUCK (A63291)
INTERNATIONAL 4900...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
