Replacement drill chucks
/ Replacement drill chucks #1
WilliamTO-35
Northeast USA
1955 Ferguson TO-35
I have three Sears Craftsman cordless drills . I've owned them for at least 8 to 10 years . I like them, I have extra battery packs, and I want to keep them . But, two of the three drills are having trouble gripping the drill bits without spinning and tearing up the bit. I've cleaned the chuck teeth , and visually I can't tell what's wrong with them. But, I'm giving up and buying replacement chucks . The chucks mount on a 1/2 - 20 spindle , with the center left hand thread machine screw in the middle. Without spending a small fortune on Jacobs chucks, what brand of chuck ( 3/8 inch capacity) do you recommend ?
Thanks.
/ Replacement drill chucks #2
You can find bits with 3 slight flats on the shank. You have to look closely as it might not say on the packaging. And there are bits with 1/4 hex shanks, too.
Bruce
bcp- Thanks for your suggestion. It's true that hex shanks won't spin, and driving screws with hex bits works fine . But, I have a large collection of conventional round drill bits ( hundreds of them) in carbide, cobalt, high speed, and Harbor Freight metal (an undefined and variable alloy) , and I need to be able to use them without damaging them.
/ Replacement drill chucks #4
Are you looking for keyed or keyless?
The last time I changed out a chuck, it was because I managed to kill the gears in an ancient B&D corded drill. I found a similar corded drill in a thrift shop, and did not realize when I bought it that its chuck was bad. I never did get the good keyed chuck off the old drill, but I did get the keyless one off of a HF cordless drill that didn't have any good batteries.
Cheapest option I have found for 1/2-20 is the 1/2 "Jacobs" at HF:
1/2 in. Jacobs(R) Keyed Chuck
I have picked a few of these up to have on hand over the years, but haven't actually used them (the drill above was also a 3/8 like yours).
I have not used the next cheapest option, which is the Ryobi at home depot. This is also a 1/2" chuck.
Ryobi 1/2 in. - 2 Teeth per in. Drill Chuck and Key-A1KC31 - The Home Depot
I think your absolute cheapest option may be to buy a cheap cordless drill with no/bad batteries from a thrift store/junk shop/pawn shop/flea market/tag sale.
/ Replacement drill chucks #5
staticmap
/ Replacement drill chucks #6
When I work my way around the chuck using the key in all three holes, have less slippage.
2025 MMS MS36C (A53317)
2025 MMS MS36C...
Light tower (A60352)
2015 BMW 328i Sedan (A59231)
2015 BMW 328i...
John Deere 5105M (A53317)
John Deere 5105M...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
2019 DITCH WITCH FX25 PORTABLE VACUUM EXCAVATOR (A59823)
2019 DITCH WITCH...
