Replacing 2-Stage Clutch In 2110 8- Speed
   / Replacing 2-Stage Clutch In 2110 8- Speed #1
KCTractors
Central Wi
LS MT357, Case 530 CK, , Ford 2000, , Ford 8N, Moline 602
I need to replace the 2-stage clutch on a 2110 . The reason is that the PTO will not stop with the clutch pushed all the way down. I would change the whole clutch-pac. My question is, can I install the clutch-pac and then just adjust the drive clutch or do I have to do something with the PTO clutch?
   / Replacing 2-Stage Clutch In 2110 8- Speed #2
Did you look at the adjusting bolts on the left side under the rubber plug, you may be able to adjust the 2 stage clutch I have a book on the 2110 4 cylinder but it dont show how much clearance but would expect it to be somewhere under .0050 and above .0020.
Walt
   / Replacing 2-Stage Clutch In 2110 8- Speed #3
I think the only 2110 with an 8 speed was a 3 cylinder model like a 3000.
That said, I have replaced a few of those and the pto clutch was already adjusted properly. So as you said just replace the whole double clutch assembly and then adjust the drive clutch.
Personally I would not do a clutch job on one of those unless I also replaced both input shaft seals into the transmission. And if your block is the newer style with the press in freeze plugs I would replace the two of them in the back of the head and one behind the flywheel. Have seen a couple of those rust out and it's always just after you had it split and back together.
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2014 Ford F-150...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
