Replacing auger shear bolts - B2782
   / Replacing auger shear bolts - B2782 #11
Ditto PILOON... I keep a small box on the tractor, which has in it spare shearpins, a tapered, flat-faced punch, paper towels, 7/16" socket/ratchet, 7/16" box-end wrench, and a small hammer.
First year I used the blower I never broke a pin... now I can count on losing at least a few every winter! :p
It also seems to make a big difference if I follow the manual- and only use 9 ft-lbs of torque, basically just enough to snug up the lockwasher. At first I wound 'em right in there, but that did seem to hasten the breakage.
   / Replacing auger shear bolts - B2782 #12
Do they make blowers with slip clutches like are found on tillers?
   / Replacing auger shear bolts - B2782 #13
Hello Ian,
No one makes make blowers with slip clutches
for residential or commercial use.
The business end of a snow blower
being the auger is always subject to
the forces created by the rotation
of the cross auger halves and the
shear pins are the simplest way to
protect the 2 stage snow blower
that employs the open auger
configuration rather than a solid auger
ribbon using a gearbox after the V belt
drive or paddle auger which is typically
belt driven.
You can use a friction disc liimited slip
clutch successfully on a rear blower when the
bottom 4 inches of the intake is protected
with a meshed frame of concrete reinforcing
mesh to prevent cobbles from entering the
the housing and shearing the pins in which
I described to a member earlier in the
week that was dealing with constantly breaking
shear pins due to his access road to hos home
being subject to ice if any wet snow is left on
his dirt road to his home which is a very high
elevation and fully exposed to high winds and
thus quickly freezing snow turning it to ice.
   / Replacing auger shear bolts - B2782 #14
All,
I am a bit confused. I own a B2789 that is mounted on the back of a BX2360. They are awesome machines. Oh yeah I snapped my first shear pin of the season and first shear pin on this tractor.
I opened the manual and it showed two shear pins. One in the Driveline and one in the DriveShaft. I snapped the driveline shear pin. Easy fix, 5minutes... first time ever.
Both of these pins hold two plates together. There is very little lining up required especially if one disconntects the driveline from the PTO. Or are you all talking about the rear bolt on the driveline?? If so I don't think this is a shear pin at all. The rearpin on my driveline is a gr12 bolt.
Below are the required shear pins for my B2789.
The driveline shear pin is a M10 x 1.25" x 45mm gr8.8 bolt.
The drive shaft pin is 5/16" NC x 1.75" gr5 bolt.
~Kevin
   / Replacing auger shear bolts - B2782 #15
I have never found any remnants of my shear bolts when they go. They seem to evaporate. :D
   / Replacing auger shear bolts - B2782 #16
I also found this to be true. Though I have only snapped on shear pin on my BX. I use to shear bolts/pins all the time back home on my family's Ford. (I was too young to understand that I needed to step off the clutch slowly.)
When I was growing up my brothers and I snapped the rear bolt at the universal joint. This bolt is not a shear pin and is a pain to line up, punch out and replace. This bolt should be gr12 bolt to ensure the gr8/gr5 shear pins snap first.
~Kevin
   / Replacing auger shear bolts - B2782 #17
Gr 12? I didn't know it went above 8. :shrug: I learn something new every few years.
   / Replacing auger shear bolts - B2782 #18
Bolt Depot - Bolt Grade Markings and Strength Chart
I didn't know there was anything higher than a gr8 until went out and examined the driveline more closely and realized the head of a bolt said 12. From my reading of wikipedia gr12 is not a steel alloy. :confused:
There is very little on the topic of gr12 bolts... I wonder why? Not many uses.
~Kevin
   / Replacing auger shear bolts - B2782 #19
It looks like the metric bolt grades are stronger than the imperial equivalents. Metric "classes" being 8.8, 10.9, 12.9 and imperial "grades" being 2, 5, 8.
It isn't a numerical continuation.. class 8.8 isn't stronger than grade 8.
Edit... a bit of conversion of units.. "proof loads" in psi. Grade 5 and Class 8.8 are very similar, Class 10.9 is just a hair over grade 8.
Grade 2: small bolts 55k, bigger bolts 33k
Class 8.8: small bolts 84k, bigger bolts 87k
Grade 5: small bolts 85K, bigger bolts 74k
Grade 8: 120k
Class 10.9: 120.381k
Class 12.9: 140k
   / Replacing auger shear bolts - B2782 #20
I use a similar method as Ductape...I try to clean the grease out of the way to better see the sheared bolt remaining, but I just spray degreaser and then do a quick swipe with a paper towel. My B2782 doesn't seem to shift like my old 2750 where you had to move the wings to get the shafts to line up, so you could then punch out the remaing bolt.
As AJL mentioned, I sheared an impellar bolt and found no reason for it, but that's a much easier changout on the 2782.
New/Unused 6ft Vibratory Roller Skid Steer Attachment (A44391)
New/Unused 6ft...
2007 JLG G12-55A 12,000LB 4x4 Rough Terrain Telehandler (A44571)
2007 JLG G12-55A...
2013 Ford Taurus Sedan (A44572)
2013 Ford Taurus...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A46877)
New Lewis Brothers...
2012 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A45333)
2012 KENWORTH T800...
2020 Terex RL4 4000W Towable Light Tower (A44571)
2020 Terex RL4...
