You might be able to compare my tractor job and the photos of the end of the shaft to the forward gear placement. just roll your nut up within ( a 1/8th inch) to load the trannys together..im sure it'll be fine. But before you roll shafts or shift gears this nut needs to be snugged tight then backed off...then re tightened to minimal tightness. 10-20 inch lbs. "DONT side load that spud bearing very much".
damit....its hard to see those shadow lines without magnifying glass on that nut. (still in a quandary how it stripped?) did you test the shaft movement forward and reverse in the rear axle
i don't think those shafts should move much ...the nut is supposed to drive the forward gear back just far enough to seat the roller bearing in its cup. They made this adjustable for the differences in gasket goo. its merely thousands of movement.
good job so far.....just move slow. I always move slow......simply because i was born in the 50s.LOL
![IMAG0578[1].jpg IMAG0578[1].jpg](https://www.tractorbynet.com/forums/data/attachments/460/460225-11e49b091ed462000fdc129efd0b1327.jpg)
![IMAG0577[1].jpg IMAG0577[1].jpg](https://www.tractorbynet.com/forums/data/attachments/460/460230-7d3b5f2003416acf63ad4078ded2fc60.jpg)
![IMAG0576[1].jpg IMAG0576[1].jpg](https://www.tractorbynet.com/forums/data/attachments/460/460245-50aa505eb43d097d850a3d3458ac32ba.jpg)
![IMAG0582[1].jpg IMAG0582[1].jpg](https://www.tractorbynet.com/forums/data/attachments/461/461063-3af4894942eff0558f41d095ac6d6c63.jpg)
![IMAG0583[1].jpg IMAG0583[1].jpg](https://www.tractorbynet.com/forums/data/attachments/461/461066-aef3f2ded7145903a6250ae0acd54cbf.jpg)
![IMAG0548[1].jpg IMAG0548[1].jpg](https://www.tractorbynet.com/forums/data/attachments/457/457278-feb3047ddda8e74c14f413d9f708e6f9.jpg)
![IMAG0589[1].jpg IMAG0589[1].jpg](https://www.tractorbynet.com/forums/data/attachments/462/462567-dc4b403d99e07fd73e8d6aeceb9f76cc.jpg)
