Resetting service indicator - Sharing how to.
   / Resetting service indicator - Sharing how to. #1
OLV1071571
Central Arkansas
Kioti RX7320P
Just wanted to share with the forum the process for resetting the service indicator. This is the process for the 3500 series so it might be different for you depending on your model.
1. Open fuse panel located under steering column left side.
2. Pull the 10a fuse from the top right of the fuse panel. Mine was labeled turn signal but the dealer said it shouldn't matter what its labeled.
3. Insert 10a fuse into the empty "reset" spot.
4. Turn the ignition to the on position but do not start the engine.
5. Wait 30 seconds and turn the switch off. (For me the service indicator did turn off)
6. Then replace the 10a fuse into its original spot
7. Start the tractor and the service indicator light (the wrench) should be off.
Hope this is helpful for the community.
   / Resetting service indicator - Sharing how to. #2
Or use a OBDII scan tool to reset it.
There you go trying to make things easy again! LOL :laughing:
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2020 Chevy Silverado (A56438)
2020 Chevy...
HUSQVARNA RIDING...
TANK MANIFOLD (A58216)
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
