Retaining wall ideas Needed - steep slope with only top access
   / Retaining wall ideas Needed - steep slope with only top access
Ok got some time to make a quick diagram of the slope etc. Bear with me in the description as I didn't have the patience to draw a topo map. The entire property is on a slight tile, mostly going from top to bottom of the diagram, but with a slight tile from left to right as well. The house site was leveled when built, as was the pool. This means that in the diagram the left side of the pool is a much more gradual slope and to go from the pool area to where you get to the more gradual slope down to the water is probably 3 - 4 feet. On the right side of the pool the drop is MUCH steeper and probably 10' to get to the more gradual slope. That slope is so steep that you cannot walk up or down it (even on hands and knees), I'd guess maybe 50 degrees? The 'gradual' slope down to the water is probably 20 - 30 degrees and from the edge of the pool to the water is likely 30 - 40 feet vertically over a distance of ~100' horizontally.
The real challenge here is that for equipment access you would come in from the right (lawn), which is the steepest side. I can get over to the left side with my tractor (have to go down through the woods or up and across a very scary slope. I cannot work from the bottom up due to the wetland buffer, which is 6' beyond the edge of the flower bed and within the extremely steep section. Contractors were thinking of cutting in from the left with an excavator and using 20 - 30 yards of fill to build up a flat area about 6' wide, which would then accommodate the toe pressure of the retaining wall and give a place to work. Given the access that's a very expensive project.
Walls under 6' in my town do not need engineering. I could probably get a wetlands permit to work into the 100' buffer zone and then restore it, but that's quite a bit of money and far from a guarantee.
   / Retaining wall ideas Needed - steep slope with only top access #22
You don't mention what the slope is composed of. Soil? Rock? Side-cast fill from the pool excavation? Each of these materials has it's own properties - weight, shear strength and soil pressure - that need to be factored into designing a retaining wall. I don't care what you call it, landscape wall or retaining wall, but you are looking at retaining soil, so it needs to be designed as a retaining wall. If it isn't properly designed, it will simply topple over with time.
Call a local geotechnical engineer or engineering geologist to come out for a consult. They are the ones who have the education and experience to design a decent, lasting wall. It doesn't necessarily have to be expensive. I like the gabion idea, but they are constructed in place, not filled and then lifted over the side. Keystone blocks are simply decorative facing, when dry stacked they don't have enough internal strength to resist the active soil forces. That's where the geogrid comes in - it increases the internal strength of the backfilled soil and reduces the active soil pressures. Same goes for rip rap, unless it's made from BFR (big f*ckin rocks).
Lastly, I'd listen to the contractor. They are the ones with experience and know what is needed for access and material movement. Working on your tractor and crossing a "very scary slope" sounds like a recipe for an injury, or worse.
/just my 2 cents
/just my 2 cents
Thanks. As described above the soil is mostly clay filled with boulders. It is well drained and stable (It's been like this for ~30 years). The slight sinking of the pool deck is probably from original settling VS the hill moving. Its well vegetated, so no erosion issues or run-off problems. My guess is that it is the excavated fill from the original house and pool construction, which means its just clay that got dug up and depending on the size of the excavator they used probably free of the car sized boulders I regularly find in other parts of the property.
Definitely worth building right. Since this is mostly aesthetic and hopefully will be small I'm trying to balance 'value' with 'doing it right'. Obviously none of it is worth doing anything that is unsafe on my tractor or with any other equipment. The contractors advice has ranged from major excavation and a face cut to pounding in a few steel poles and putting a 2x6 flat between them to hold up the last foot of soil to make the flowerbeds level (not considering this one...).
   / Retaining wall ideas Needed - steep slope with only top access #24
... I don't care what you call it, landscape wall or retaining wall, but you are looking at retaining soil, so it needs to be designed as a retaining wall. If it isn't properly designed, it will simply topple over with time.
/just my 2 cents
I agree any wall needs to be engineered in order to resist soil movement. But, if you call it a Retaining Wall, the town will demand engineered drawings which can be very expensive. For a Landscape Wall, they will be satisfied with pre-engineered examples from the Keystone website and brochures. This is much less expensive than the custom drawings they want for a Retaining Wall.
An engineer such as you suggest is a very good idea, and will save money in the long run. Again a Landscape Wall can be built from informal sketches, which are vastly less expensive then formal drawings.
The Keystone blocks are much more than decorative facing. They have examples of the use of their blocks which will produce a wall good enough for almost any application under 4', which is higher than the OP needs. Used with their geogrid, and their recommended backslope (they call this "batter") you will hit a home run every time. The wall will be stable and safe.
If you use one of the canned designs, a strong, decorative and good-looking wall becomes a DIY project.
I built more square feet of wall than the OP with a crew of 2 to 3 day laborers and directions from me. I needed engineering because of the height of my wall, but with low wall like the OP is mentioning, a 3-4 hour visit from an engineer just as a sanity check, and a small crew will be sufficient. In many instances I have found that contractors will push an owner toward techniques the contractor is familiar with, and will almost always be more expensive then a DIY project. This wall is so small that a tractor is not needed. You would be amazed at how much material an experienced laborer can move.
Tip: Look at different types of walls and check to be sure the engineer you call can design with that rock. Companies like Keystone sell computer programs specialized for their product only. If the engineer already owns the program he will have a minimal charge for using it. If he has to buy the program he will either turn down your project or charge the full price (expensive) of the program.
   / Retaining wall ideas Needed - steep slope with only top access #25
I have built keystone walls over twenty feet in height. They were engineered and used geogrid.
In most states the height of the wall determines design required for plan approval
From description of site, it seems the wall will be located on a previously filled area. An engineer will be able to determine bearing capacity of the soil.
For short walls the design is fairly basic, I have used the blocks interchangeable to the design. The different types of blocks are slightly different in size
   / Retaining wall ideas Needed - steep slope with only top access #26
We used Keystones on my neighbor's wall. It's apx 8' high and probably 85' long with geogrid and has a slightly meandering design...it's holding back a wall of vertical waterlogged shale from the massive pasture above it...We
French drained and center and back filled with gravel..It has held up very well and looks spectacular.
Thanks for the good ideas, keep them coming. How would I go about finding an engineer who could do something like tell me what the bearing load for the soil is? Do I just look up landscape engineers, or is there a specific type of engineer that specializes in this type of thing?
   / Retaining wall ideas Needed - steep slope with only top access #28
... Do I just look up landscape engineers, or is there a specific type of engineer that specializes in this type of thing?
Look up geotechnical engineers.
   / Retaining wall ideas Needed - steep slope with only top access #29
On the wetland buffer, do you own the land to the water? Outside of the wall, I was wondering if it would be cool / appropriate to put stairs down to the waterfront.
   / Retaining wall ideas Needed - steep slope with only top access #30
In my city permits and engineering are often required for the simplest of projects plus design review for astetics is often thrown it.
A very large home went in across the canyon... 12,000 square feet and a lot of grading and tons of piers required for the home...
I mention this because the project also required and extensive retaining wall... the owner had an excavator and trucks delivering large boulders for nearly two weeks... no permit or engineering required because it was natural stone... found it odd and the HOA did research and found the same...
Looks magnificent and blends in well... the contractor does a lot of Napa and Sonoma wineries.
   / Retaining wall ideas Needed - steep slope with only top access #31
I mention this because the project also required and extensive retaining wall... the owner had and excavator and
But, under 4 feet high, correct? Otherwise, engineering and a permit are still required, as Dave mentions above. The
4-ft limit includes the height (thickness) of any footer.
   / Retaining wall ideas Needed - steep slope with only top access #32
6 to 7 feet... boulders as large as a VW Bug... individually placed.
Yup, I own down to the water. The hill levels out a bit on the side of my land and I have a tractor trail down to the water. Its all open so a great view and that side of the hill is grass, so an easy walk down to the water (or drive). I'm putting a dock in (getting permits in spring), which will give me something to put the kayaks etc on. it'd be great if I could make the whole thing a nice sloping hill of natural grasses or something, but they basically don't want you to touch in the 100' buffer zone at all
   / Retaining wall ideas Needed - steep slope with only top access #34
Could a concrete pump truck boom reach the area? They can reach a good distance and over things, not sure what the practical limit is.
That would fix part of the heavy equipment access issues if you could pour a retainer of some type in place.
I actually had given this some thought as it would be a great solution and I could hand dig out the area and put in forms pretty easily. The problem is I think the truck would be on the other side of the house. Not sure on the range of those, but I believe it would be about 100 - 150' horizontally and would have to go over the house and then down probably 30' to account for the downward slope. The side yard is steep and grass so I think if I put any big truck in there I would rapidly be in trouble.
   / Retaining wall ideas Needed - steep slope with only top access #36
Check with your state EPA regulations and local building/zoning restrictions. Your land might not be considered wet land until you get within 50 feet of the shoreline of the lake/pond; unless you have typical wetland flora growing there like cattails, sedges, or reeds. Also check to see how hard (and fees) it is to get a waiver to put the wall closer to the shore. Finally, there are always exceptions to rules. Some wetlands work may be allowed without permit or study if it's all done by hand, and not by machine.
Thanks. I had the conservation guys come out and flag my wetland border (defined by I believe 50% of the plants being wetland types). For me this is luckily right at the waters edge, which gives me more room to play with. Within the 100' zone its easier to get a permit, especially if just doing temporary work - but there are mitigation measures and its relatively expensive. Within 50' they don't want you doing anything, again you can try to get a permit, but the mitigation cost goes up and in my town they tend to lean towards not granting permits.
I could take a huge risk and just do stuff and hope no one measures, however the penalties are severe and a neighbor just got fined $70k+ for clearing trees in the buffer area (they take it pretty seriously here). Given that I'm going to go by the letter and be really careful.
   / Retaining wall ideas Needed - steep slope with only top access #38
The Shoreland Zoning buffer in Maine is a separate thing from wetlands. They really don't care how wet or dry that buffer zone is in determining what can be done within it.
I would ask your local folks (code enforcement, planning board, or equivalent) about your project if you haven't yet. Usually if you explain what you are trying to accomplish they will tell you what you can or can't do, explain the regs, etc.
I sit on my town's planning board and it seems like granting shoreland exceptions is not really going to happen here. I'm the most junior/least experienced member of the board so I try to ask intelligent questions and provide a voting quorum. :D Two board members have houses on the local lake and they follow the letter of the regs in deciding what can be done in the buffer zone. The board has granted some minor exceptions in non-shoreland areas, so it isn't like they just want to be buttheads.
You for sure don't want to attract the attention of the MA DEP or the local boards in a bad way.
It would probably pay to ask about the concrete pumping possibilities although it does sound like too far. Maybe it's doable, maybe not, or doable but no one has the equipment near you and/or too expensive.
All great advice. I had the guys from the committee out to take a look and give advice. It helps a LOT to play nice with them, then if there is a mistake they know you are trying to do the right thing. I used to sit on a planning board years ago in another area as well and in general they want to help you VS hinder you - if you work with them.
I may call around on the concrete idea. I wonder if they can pump through a pipe that's rolled out or something, which could work.
   / Retaining wall ideas Needed - steep slope with only top access #40
Does the water stay in a constant channels, is the bank covered with vegetation or eroding. Scour is moving water eroding under a fixed structure To OP for wall under four foot height go with precast block as curly Dave mentioned. Check building supply to see what is sold in your area. Both types that he mentioned are good products
The creek is very stable, in fact it runs right over rocks. Also there will not be any scouring, since the retaining wall would be virtually sitting right on the bed rock beside the creek.
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
Topsoil Trommel (A57453)
Topsoil Trommel...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
