reverse direction
   / reverse direction #11
Too bad you’re a little distance from me. Our shop is setting up a 100 hp hydraulic test bench this next couple of weeks. That pump would be perfect to try out.
   / reverse direction
I'm not sure I want to put 100 hp to these old buggers. lol. However, your welcome to bring the motor here and put it in my bobcat, ( just to check it of course) .
   / reverse direction #13
Lol.......not that kind of motor. It traveled from Billings MT and it won’t be moving anywhere soon. Electricians are wiring it this week.
   / reverse direction #15
We’re hoping, it will test pumps and motors dynamically up to 100 gpm/5000 psi. Having a soft start installed to keep the elec man happy.
   / reverse direction #16
Sundown,
I struck out in finding any parts breakdown documents for those older transmissions. I did find a technical data sheet for the TA1919 series which I believe was similar to the TA1515 and they do show exactly what you are describing in having the vane pump as external charge. So I agree with your finding that you will have to change rotation on the vane pumps but hydrostatics might operate in either direction. Not 100% convinced since still not sure if the port plate, or lens plate is the same on both.
   / reverse direction #18
Oldnslo,
The TA1919 uses a wafer plate that is right or left, if it was his case the two wafer plates could be swapped around between the pumps. But as he says I seem to recall the TA15 pump rotating group is directly riding on the housing, similar to PVB series piston pumps. Not sure, but just an educated guess.
Here is a pic of the TA19 wafer plate, you can see they come in left or right config
   / reverse direction #19
Ooops, I see now you have the info........;)
   / reverse direction
I just dont know if i have TA1515 or TA1919. cant find any numbers on it at all
John Deere 50 (A53317)
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2002 Isuzu NPR-HD Truck, VIN # JALC4B14727002397 (A56858)
2002 Isuzu NPR-HD...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A55851)
2018 Kubota RTV500...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
