Reverse stopped working
/ Reverse stopped working #21
I'll follow through with directions on fuel and water thanks.
On the forward reverse issue, it starts if I push in the reverse pedal, but still only operates in forward.
When you look underneath, you will see the two devices that tell the controller to go F or R.. I normally would call them pots, or variable resistors, or whatever. But now days, they could be just about anything. Good luck, Jerry..
Banged on both F and R pedals a few times and now that issue is resolved. JerryK was correct on wires being exposed, shorting fuse for water in fuel. I fixed the wires.
Next question. If I pull the water in fuel drain off, should it drain continuously until the gas tank is empty or is it just whats in the water separator tank?
Reason I ask, I drained like you said, reattached, and light stayed on. I started without it plugged in and light was off. It just drained for 30 seconds and now a drip every 3 seconds. Is this normal? I'm about to reattach and see if light goes off.
/ Reverse stopped working #24
It will drain the tank completely.
Is there a blank place in the fuse block where you plug in a fuse and do a reset?
Some tractors have that,,,
/ Reverse stopped working #25
All you have to do is back the sensor out a little until it starts draining, do not have to or would you want to take it all the way out. Or it would probably drain the tank like you thought. Once you get clear diesel, just tighten it back up. A lot of diesels use this type of system. It puts the sensor in the lowest part of the fuel system where the water will congregate to, and simple to drain... I don't know about the reset, or even if you have to. I would think it would just go off once you get the water off the sensor. In all my years of running diesels, I don't remember ever having water in the fuel lines.... I always keep my tanks full with clean fresh diesel... You probably don't have water either, just the wire problem...
/ Reverse stopped working #26
My antiquated tractor has no electronics to show water presence,,,
In my fuel/water separator,, there is a red ring,,,
if the ring floats, drain until the ring is back down.
You can see the "wingnut" drain at the bottom.
Ohhhhhhh,,, the horrors of having "old" technology,,, :eek:
:laughing:
:laughing:
Lol. Sometimes technology is a pain in the butt.
Fixed the reverse issue. Thanks to all.
/ Reverse stopped working #29
If you get a chance can you post a photo of what was fix or adjusted. I've got a feeling others will appreciate knowing how to fix this issue.
After trouble shooting everything that JerryK suggested I finally just banged the forward and reverse pedals several times and it finally worked. I couldn't see any debris or sticks anywhere in the way. It's just crazy that this happened the same time the water in fuel went sensor went off as well as me finding fluid leaking underneath. I'm still trying to find out what the hole is underneath leaking fluid. Thinking a possible weep hole?
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2020 HAMM H7I COMPACT LINE SMOOTH DRUM ROLLER (A59823)
2020 HAMM H7I...
Toro 7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
Toro 7-Gang Reel...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
Lot of 4 10-16.5N.H.S. Skid Steer Wheels and Tires (A59228)
Lot of 4...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
