Revised Ohio Commercial Vehicle Rules
   / Revised Ohio Commercial Vehicle Rules #21
Incorrect, FEDERAL is any vehicle with a towed unit that is over 10K that crosses state lines OR a 26,001 GVW (license, rated, actual) unit with or w/o towed unit.
Laws very by STATE that may say the total GVW of both needs to be over 26K, I know MN is this way, but Federal is anything in commerce with a towed unit over 10K crossing state lines.
Sorry Bud you are wrong here.
Question 2: Is a driver of a combination vehicle with a GCWR of less than 26,001 pounds required to obtain a CDL even if the trailer GVWR is more than 10,000 pounds?
Guidance: No, because the GCWR is less than 26,001 pounds
Interpretation for Part 383.91: Commercial motor vehicle groups. - Federal Motor Carrier Safety Administration
   / Revised Ohio Commercial Vehicle Rules #22
One of the trucks is registered to my wifes business. The other is primarily used for maintaining and rehabbing investment properties. This truck is only driven by me. I am not exactly sure if that truck is "commercial" or not.
Trailers are pulled by both trucks for personally owned rental/rehab properties. The trucks are not driven by employees.
When you pull trailer for rehabbing rentals you are technically a CMV. The odds that you ever get busted for this are slim to none if you don't mind fibbing a bit if you get pulled over. It also make no difference if it is owner operated or employee operated.
I wonder if the guy hauling personal tools to jobsites would be considered a cmv?
   / Revised Ohio Commercial Vehicle Rules #25
   / Revised Ohio Commercial Vehicle Rules #26
What if his "tool" was a D-11 Caterpillar? :laughing:
Where is the line drawn?:confused:
Then it would be kind of moot anyway since he would need a CDL.
Simply put if I haul "my" tools as a self employed contractor in a truck or combo over 10k GVWR/CGVWR/GVW it is a CMV.
If I haul my tools as an employee of someone else it would not be.
That is what bothers me about it. The guy that has a 1 Ton truck for pulling his weekend toys. Or the finish carpenter that pulls a trailer because he prefers his own tools.
That being said, I have also been in some pretty scary under 26,000 lb company trucks.
2008 Ford F-450 Crew Cab Utility Flatbed Truck (A55973)
2008 Ford F-450...
7ft Double Legs Lifting Chain Sling (A57454)
7ft Double Legs...
1999 NUTTALL FOUR AXLE TRAILER (A58214)
1999 NUTTALL FOUR...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58216)
2008 TEXAS BRAGG...
