Reviving batteries
/ Reviving batteries #1
sitiak
clearfield utah
kubota
Looking for ways to revive "dead" batteries i.e. sealed lead acid, ni-cd etc.
/ Reviving batteries #2
Take a look on You Tube. There are dozens of great videos. One guy hooked up a 12V car battery and just touched it to the contact points on dewalt dead battery and brought it back to life.
Other use another battery in a series to charge a dead battery. I did this and it really works.
Couple other have a solution to pour in ( I think salt of some sort ) and it breaks up the corrosion in a battery between the plates.
/ Reviving batteries #3
Also search on TBN. There have been a few threads in the past on this subject.
Ken
/ Reviving batteries #4
I used to revive old Ni-Cd batteries using a technique similar to what Cat_driver describes. As I refined my technique I learned more about what I was doing.
Some key points;
It's dangerous. You need to build a blast box to contain the battery during the process and safely direct the energy of a malfunction.
Cadmium is a toxic heavy metal. If a battery does go off, you have problems.
Once I had the information on Cadmium, I no longer had any interest in reviving batteries and I disassembled my set up.
/ Reviving batteries #5
Before trying to revive, recommend taking to Advance Auto or Auto Zone...or similar car places. They will conduct a "stress test" to ensure the cells are connected and working. No need to try fixing something that is too far gone. Especially a battery that may explode! Flying acid can ruin your whole day.
Obviously....I misread the initial post....we're not talking tractor batteries. My bad.
/ Reviving batteries #7
While I have dismantled and replaced bad cells in Ni-Cad drill batteries, I would never expect to get much more life out of them before the next cell dies. As far as lead acid batteries are concerned I don't believe in free lunches.....
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
New Holland T5 120 Tractor (A64047)
New Holland T5 120...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63118)
2006 Cadillac...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
iDrive TDS-2010H...
UNUSED CFG INDUSTRIAL MH12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
