rewiring a 725
   / rewiring a 725 #1
cmyoung2
Platinum Member
North west NC mountains
BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
I have a 725 with the 8hp kolher with electric start. Switch is worn out, going to replace it with a simple on/off switch and a push button start. The old switch has a 5 pin plug + a ground pin. How do I tell what wires do what?
   / rewiring a 725 #2
Take a testlight(or a voltmeter) and determine which one is live to the battery. Next flash a jumper wire from that one to each of the others one at a time to see which one is the start. The others must be for ignition/accessory or whatever other circuits your machine might have, and can probably all be hooked together on the load side of your new switch. You may be able to tell by the size of the wires. Larger wires usually indicate battery/charge system, start terminal. Smaller ones for ignition and other circuits. Not sure what a 725 is, or how many circuits might be associated with a key switch, but a ground is usually not necessary on most machines. Once you identify the battery and start wires, the rest should be self explanatory.
   / rewiring a 725 #3
You can find the wiring diagram here: Service // BCS America
Go to the Tractor Parts List for the 725. Kind of hard to read but may be better on a bigger screen and / or printed.
   / rewiring a 725
Thanks, Got it done today. Mounted the switches on the handle bar, everything seems to work fine.
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2018 Toro Sand Pro 5040 Bunker Rake (A59228)
2018 Toro Sand Pro...
2017 TERRAMAC RT14 CRAWLER DUMPER (A60429)
2017 TERRAMAC RT14...
RoGator RG1100C (A61307)
RoGator RG1100C...
