Right to repair - we WIN!!
   / Right to repair - we WIN!! #21
What's going to happen is these companies will make more money. Instead of withholding the software needed to troubleshoot your equipment they are going to sell you access to an on-line version of the software for a limited amount of time. You'll plug your computer in and it'll spit out an answer. They'll even make sure the part is at your local dealer for you to buy.
   / Right to repair - we WIN!! #22
Yep, and guess what, the parts are going to be expensive.
   / Right to repair - we WIN!! #23
The first thing the customer will have to do is buy the protocol adapter in order to connect a laptop to the machine.
Dealers currently pay several hundred dollars for each configuration. How many will you need?
   / Right to repair - we WIN!! #24
I'm not holding my breath on this one ............
   / Right to repair - we WIN!! #26
It could still be years before regulations are written, and legal challenges are settled.
I would like to be able to buy Apple OEM parts. They only sell them, if you allow them do the work.
Never underestimate the power of the government (or sometimes, the stupidity of it).
Do you have an OBD II port in your car? Yep, and you can buy a reader for $20 on eBay, a rather good one costs a bit more, and there are readers in the several hundred dollar region for specific cars (MB, BMW, etc.) Even Harbor Freight sells them (but no more coupons, I guess Comrade Xi needs the money . . . )
OBD II was mandated by the Feds about 25 or 30 years ago (I had a 1990 Audi with OBD-I, it would blink out a few codes), OBD II works very nicely, and I have a brand-specific reader for my MB. It cost something like $399, but it has saved me many multiples of its price. Plug it in, it reads EVERYTHING and saves hours and hours of diagnostic time (the dealer gets $150/hr) plus running the car back and forth, alternate transportation and so on. In fact, I bought it used from someone who wrecked his car, I paid him a whopping $50 - and it saved me ten times that the first time I plugged it in.
So here I am in the middle of a field, my tractor stops and I don't know why. Has fuel, no nasty noises, nothing obviously busted, it just won't run. Plan A - load it onto a trailer, take it to the dealer, pay $$$$ for diagnostics, pay $$$$$$$ to have the parts installed, put it back on the trailer, take it back to the field and go back to work. Total time a couple of days and boo-coo dollars.
Plan B - plug in the $300 diagnostics box right there in the middle of the field, it tells me I need part number 34-3456B, which is a left handed widget frammis solenoid and my dealer has one in stock right now. Go get it (leaving the tractor where it is), bring it back, install it myself in eight minutes, back to work the same day.
I like Plan B, it is worth paying the $300 for the magic box because it gets me up and running FAR faster and for FAR less money and with FAR less hassle than Plan A.
Vehicles of all kinds nowadays are much more complex than in the old days. Part of it is they are more capable, and part of it is various regulations. Diagnostics can get very expensive with all these interrelated systems, which is why OBD II was mandated in the first place - there was no confidence that repairs would be done to satisfy emissions requirements given the complexity of the systems.
The only constant is change . . . if we are lucky, this will be for the better. Captive service and captive parts are definitely no bargain for us. The FTC is getting ready to break that barrier so we can fix our own stuff again.
Best Regards,
Mike/Florida
   / Right to repair - we WIN!! #28
Yes, that would be a "magic box" if that is how it would work. Normally, a service code may tell you that you have low fuel pressure at the injectors and you have to still figure out if it is a plugged line/filter, water in the fuel, stop solenoid, or lift pump. Maybe the code tells you that there is still a safety interlock enabled and you have to figure out which switch it is or if you have a short. It seems like the dealers will be stocking lots of parts for people doing plan B.
   / Right to repair - we WIN!! #29
As Ruff says it's not that simple. Plus when it comes to cars there's a lot of them out there. That means a massive market. Not the case with tractors so don't expect companies to line up with cheap versions of what the mfg sells. Even with cars there's generic codes that all use then their brand specific codes and codes in sub computers. The cheap code readers don't usually read everything.
   / Right to repair - we WIN!! #30
Mike/Florida
That sounds like a desirable outcome, and actually could be realistic, except maybe the 8 minutes parts replacement;)
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2020 JOHN DEERE 8R310 LOT NUMBER 210 (A53084)
2020 JOHN DEERE...
RV Hitch (A50121)
RV Hitch (A50121)
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
