RK24H Dead?
   / RK24H Dead? #1
MFFAL
RK24H
Got an RK24H brand new Spring 22’. Lightly used, only for bush hogging and moving brush with the grapple or gravel with the bucket (very light loads). I’ve got 29.3 hours on it.
Issue: Tractor randomly shut off on me while I was driving to hook up the bush hog. Topped off fuel, still wouldn’t start (same fuel in my diesel truck that’s still running). No lights except “oil pressure light” it will turn over but won’t crank . Spoke with the RK mechanic and he suggested I remove the “clear filter tube” and pour it out then clean it with fuel and reattach. I did this, cranked the tractor and it started. About 20 seconds into the start it blew white smoke from the exhaust and didn’t stop so I turned it off… well it kept blowing smoke and more and more and it didn’t shut off. I even pulled the key out and it filled the sky and everywhere around the tractor with white smoke for about 3-5 minutes before it finally stopped.
RK says they don’t know when they can get someone out (they’ll call me again Friday with an update) and I can’t bring it to them. Has anyone had this happen? Nobody I know that has familiarity with tractors has a clue including the mechanic I spoke to on the phone.
   / RK24H Dead? #3
I don't have the same tractor but I had a fuel shut off solenoid go bad and shut down 2 out of 4 cylinders... The result was exactly what you describe. Run on (dieseling) and white smoke
Dramatic but am easy fix and no lasting issues. Good luck .
   / RK24H Dead?
Yeah, RK ended up sending a mobile tech out and took it to my nearest RK which is 1.5 hours away. So maybe they’ll solve it. They obviously couldn’t diagnose it on site and had no clue when I told them over the phone. It smoked pretty bad, to the point you couldn’t see the tractor anymore and it covered 1/3 of my property
   / RK24H Dead? #5
Hope they answer fix and get it back quickly.... Update us pls
   / RK24H Dead?
Bother them. At the very least, weekly; keep being a pain in their ass.
They said “water in the fuel system” and “oil overflow”.
The tractor has 29hours has been refueled a hand full of times. Tractor was running fine, shut off and gave an oil pressure light. Not even at its 50hour service. Said warranty won’t cover. I call BS and am waiting to hear back.
   / RK24H Dead? #10
I wonder if the head gasket let go and dumped water in the oil and perhaps it also made its way into the fuel or injector pump.
Double Diamond 3pt 7' Mower (A46443)
Double Diamond 3pt...
2008 AA WELDING MONORAIL (A47001)
2008 AA WELDING...
2019 RANCO ANVIL END DUMP (A47001)
2019 RANCO ANVIL...
2003 TRAILMOBILE 32FT DRY VAN (A43004)
2003 TRAILMOBILE...
2017 TEREX USA LLC RL4 LIGHT STAND(INOPERABLE) (A47001)
2017 TEREX USA LLC...
John Deere Pull Type Planter (A47809)
John Deere Pull...
