ROAD MAINTENANCE/EQUIPMENT with PICS
   / ROAD MAINTENANCE/EQUIPMENT with PICS #31
SkyPup said:
Real nice informative post, enjoyed the photos too!
I maintain a 3.5 mile road primarily with my Kubota L-3130 GST with a BushHog 96" box blade and 3pt TNT setup on the rear end. Our road is limerock base with recycled concrete gravel on top about #57 size. Lots of rain and lots of dry heat throughout the year. The landscape rake doesn't work on our road since about 3/4 of the road is hard base capped off, only about 1/4 of it is soft due to drainage and that is the part I work the most on.
One of the main points is to NOT grade too fast. I normally grade at around 3.2-3.7 miles per hour and find that even going 4.0mph is too fast. That is about 1,500rpm in 10th gear.
Here are a couple of pics:
good point about grading at the right speed, i know my old cat grader gets just that right speed where it has the momentum to knock stuff free without shaking and the speed to spread the dirt in a nice even flow
   / ROAD MAINTENANCE/EQUIPMENT with PICS #32
dirtworksequip,
I'm impressed with how you are able to maintain grade with your FEL. In S. Louisiana, bionic blade boxes are the ticket. I'm sure you are familiar with them. Makes even a novice look good. I generally grade both outer edges first and then finish up in the center on the last run. Usually end up with a good crown.
   / ROAD MAINTENANCE/EQUIPMENT with PICS #33
When I blade a road with a motor grader, I will pull the windrow from one side to the other which levels out the road. Then I make a second pass with the blade slightly off the ground. This removes the rocks and leaves the fines. The fines are what gets compacted with traffic and makes a durable road. I don't like to leave any rocks that are larger than 1/2". Crusher run is ideal for a road because the sharp angled edges lock together unlike round stone which will push out from the tires.
Thanks BayouMan, I always pride myself in doing the best I can. I had thought of purchasing a bionic blade,but just couldn't justify the cost.
They do an incredible job though.Some of PA townships use them on the stone roads they maintaine.
   / ROAD MAINTENANCE/EQUIPMENT with PICS #35
My brother and I made our own bionic blade. Probably cost us about $200, 7 or 8 years ago.
If you are interested, I can take some pictures of ours, along with some recommended changes. Took us about 2 weeks working evenings and weekends to complete.
BayouMan
Thanks for the offer on the bionic blade, but I'll just stick to using my front blade and landscape rake for the maintenance I have. If it was going to be an on going thing I would consider the bionic blade,but eventually the road will be shot and chipped or paved. Thanks again.
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
Hustler Raptor Limited Zero Turn Mower (A51573)
Hustler Raptor...
