Roll pin removal---Any advice or tricks
   / Roll pin removal---Any advice or tricks #41
easy.. don't cut the hub.. cut the race.. :)
if you adjust your torch correctly, you know exactly where it cuts at...
the welding trick is the ticket though. as the race cools it draws and shrinks the OD
just don't weld tru to the hub.
use low penetration rods.. like a 6013 on ac, and low amps. just want to draw a bead around the inner face of the race..
In some cases I have even use that technique to shrink the ID of a splined tapered sector steering arm so it fit a sector shaft better / farther out.. etc. that and pounding ont he flat open face of the arm-hole will shrink the ID and expand the od.. etc.
lotsa tricks...
   / Roll pin removal---Any advice or tricks #42
What if I only have a MIG and torch, am i out of luck with the welding trick? Its a Pro MIG 175 by Lincoln.
   / Roll pin removal---Any advice or tricks #43
why would you be out of luck?.. I think it will likely be easier with a mig.. even a flux job.
soundguy
   / Roll pin removal---Any advice or tricks #44
What the others have said, but also get a roll pin punch set. not the same as a drift pin punch.. notice the little round end that goes in the hollow of the roll pin and still has a sharp shoulder. This is to help from "peening the pin to the inside hollow space" if that makes sense.
Amazon.com: Grip 9 Pc Roll Pin Punch Set: Home Improvement
James K0UA
Wow! Great advice, I did not even know such a set existed.
Amazon is currently sold out, but Newark has them:
GRIP ON TOOLS|61135|9 PC ROLL PIN PUNCH SET | Newark.com
SK tools also makes a set, but for SK quality/name they are about $40 more than the Grip set.
Regards,
Steve W.
   / Roll pin removal---Any advice or tricks #45
Regards,
Steve W.
I have had a set since i was 16, so let me see that is...... well I have all my fingers n toes out, and still need more appendages to count that high
:eek:
   / Roll pin removal---Any advice or tricks #46
Personally I use a hammer first to drive the pin in if it is sticking out, then I use as big of a standard punch as I can get in the hole to start it. Then use the proper size pin punch to drive it out. Be sure the punch end is flat, and hit it hard the first time.
   / Roll pin removal---Any advice or tricks #48
If you try cutting with a torch, how do you not damage the hub? I only had lots of sparks flying when I tried cutting metal with the torch. I'll have to give the welding idea a try next time too.
Theres a visual change in the sparks that I have been told about. I wont be trying it. Put a weld bead on and shrink it out for me. :)
larry
   / Roll pin removal---Any advice or tricks #49
Hitting the pin directly is an error large or small. There is much more risk of deforming the end with a direct blow. Something in between will aid alignment and make it less important to strike perfectly. Use something fairly short and fat so the energy of the blow is delivered sharply. A 1/8 -1/4 thick piece of strap metal works well ... then its punch time. :)
larry
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A56438)
2015 Bobcat S650...
TANK MANIFOLD (A58214)
