Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
easy.. don't cut the hub.. cut the race..
if you adjust your torch correctly, you know exactly where it cuts at...
the welding trick is the ticket though. as the race cools it draws and shrinks the OD
just don't weld tru to the hub.
use low penetration rods.. like a 6013 on ac, and low amps. just want to draw a bead around the inner face of the race..
In some cases I have even use that technique to shrink the ID of a splined tapered sector steering arm so it fit a sector shaft better / farther out.. etc. that and pounding ont he flat open face of the arm-hole will shrink the ID and expand the od.. etc.
lotsa tricks...
lotsa tricks...
