Rolled my 3240, and it ran till it blew ??
   / Rolled my 3240, and it ran till it blew ?? #91
This incident scares the crap out of me. The thought of a crankcase vent tube supplying a runaway to destroy a new tractor is difficult to take in, considering that all one would need is a catch can. This makes me want to look over my bx25 and see how it is arranged. Heck I'll invest in a $80 piece of security to help prevent it.
Jaz 605-325-01 - Jaz Products Breather Tanks - Overview - SummitRacing.com
later
   / Rolled my 3240, and it ran till it blew ?? #92
later
I think you are saying that by re-routing the crankcase vent line from the tractor's air intake to a unit like the example one pint Breather / Catch-Tank, there would be no fuel in case of a roll-over. Is that correct? It seems reasonable.
Has anyone used this unit or something like it? How would the size be selected to suit the engine?
I see that Amazon has the Jaz Products 605-375-01 Mini-Breather Tank with 0.375" Fittings
for $50, but no photo there for comparison with the unit offered by Summit Racing.
   / Rolled my 3240, and it ran till it blew ?? #93
I appreciate all the varied opinions offered in this thread. My opinion is a little different. In my experience I have never seen or had a 4 stroke diesel engine run away, now I am not saying that they can't run away, just saying it is extremely unusual and extremely rare for it to happen. I have seen 2 strokes run till they grenade and for different reasons. 1- mechanical governor failure, (the most common but can create the drafting issue). 2- the scavenging of oil vapors from an engine with overheated oil.
Now with that being said I would like to offer a different scenario. If a diesel engine has glow plugs it is a lower compression engine that needs the glow plugs to heat the cylinder air to aid, or in some cases completely enable cold start combustion. Now here is my point, how does this lower combustion engine have enough compression to ignite straight engine oil let alone synthetic oil?
I think that oil was mixing with fuel, the fuel was running the engine and the oil was creating all the smoke. What are the chances of lets say, maybe a fuel rack sticking because it was on its side?
Another clue, of all the posts in this thread I did not see one time where it was stated that the engine ran to over speed, just that it was running at wot. I also think that the increasing volume of engine oil entering the combustion chambers is what actually shut down the engine.
I say check your ignition switch and safety switch's.
JMO folks, flame away.
   / Rolled my 3240, and it ran till it blew ?? #94
Not unusual at all for a diesel to run on oil once it is warmed up and running. With positive crankcase ventilation and an upside down engine it would run until it ran out of oil.:cool:
   / Rolled my 3240, and it ran till it blew ?? #95
See: Diesel engine runaway - Wikipedia, the free encyclopedia. It is more common on older turbodiesels with bad turbo oil seals or on engines with loose valves/rings, but it has been known to happen.
Most diesel engines have glowplugs or intake heater grids. This is because when the block is cold, it cools the air as it is compressed, preventing the air/atomized fuel from reaching the ignition temperature. See: Glowplug - Wikipedia, the free encyclopedia for more details. Once it is hot, it will burn most anything flammable
Well from what the OP said (bolding mine):
Now I am REALLY POed!!! the darn thing would not shut off!!, I pulled the key, hit every safety switch, made sure the seat safety switch was depressed and hit the go pedal, kicked in the PTO, pulled all the fuses, made sure the throttle was at idle, I couldn't get the hood open to get to the air cleaner, the darn thing just screamed wide open and blew all the oil out the exhaust until it quit, probably 10 minutes, (seized I suspect)
I would say that it was running a little faster than normal. But that is just me.
Aaron Z
   / Rolled my 3240, and it ran till it blew ?? #96
Completely untrue on both counts. Only light duty diesels have glow plugs or grid heaters. The class 6 market just recently started to use grid heaters on certain applications. 27 years of wrenching on class 6 and 8 trucks I will take my training from the pro's at Cat, Cummins, Navistar and a little bit of Detroit. You can use Wiki.
Put gas in your Bota and let us know how that works out for you.
   / Rolled my 3240, and it ran till it blew ?? #97
Sorry, I see someone else suggested the same solution earlier
   / Rolled my 3240, and it ran till it blew ?? #98
A friend of mine has a Bobcat Trachoe with a 13HP Kubota engine. He drooped it off a sidewalk a few years back - just one track - and it fell over on it's side. He dove off just before it hit but still got one foot stuck. The hoe was still running, but not racing.
Someone on the job site came over and helped pull him out. When his other worker and me came over, the hoe was still running. It did shut off with the key.
A loader worker on the site came over and lifted his hoe upright. We cranked it up and moved it squarely on the sidewalk. Since his foot hurt, I finished the ditches and digging for the day.
It took several months before his foot was back to 100%, though he still has some problems with it off and on.
We have used the hoe quite a bit since over several years, quite hard at times and it never suffered from the fall.
Like someone mentioned, if yours isn't working (seized up or such) I would try to get Kubota to fix it.
   / Rolled my 3240, and it ran till it blew ?? #99
I liked the suggestion (about 30 posts back) to use a fire extinguisher. With a CO2 extinguisher (NOT dry chemical), you should be able to aim it at the engine cowling and let fly. The engine will suck it in and, with no oxygen to support combustion will shut down. It's cheap, would not do any harm to the engine, could be easily mounted, and it's handy if you run into -other- problems.
   / Rolled my 3240, and it ran till it blew ?? #100
AMOT, Barber Coleman, Rig Saver... seveal manufacturers make positive ASO's for diesel engines.
The easiest to install is an inline into the air stream with a 12v actuator to trip it off of a momentary switch. Basically push a button, the actuator releases the spring loaded shaft and it slams closed.
As for the CO2 idea, yes, it WILL work, but remember, a diesel will continue to run at less than 1:1 AFR, in other words, while you can kill a gas engine by taking most of the air away for a few seconds, a DIESEL will have to be completely WITHOUT oxygen until the crankshaft comes to a complete stop. SO make sure you aim well with the CO2, and make sure you have enough..
4Stroke engine WILL run away.... I've been there and seen it happen... I've had 3000HP engines try to get away from me.. Good thing the engine had Barber-Colemans on it... Had a 1000 hp. wood chipper engine that did get away with no ASO's and didn't stop turning until it threw the valvetrain apart.
A cold diesel at low idle usually won't run away on a little oil, but if the engine is warmed up or has some speed on it and gets a snort of warm/hot dirty oil.... she's heading for the moon!!!. Shutting of the air supply is the ONLY way to effectively kill a runaway.
On smaller engines with no ASO's... If I've done major work concerning the fuel system, I pull the intake plumbing and keep my clipboard handy..
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A57193)
UNUSED JCT 84" HYD...
2021 Ford F-600 4x4 Mechanics Service Truck (A55852)
2021 Ford F-600...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A57024)
2002 Chevrolet...
2011 Kia Forte Sedan (A55853)
2011 Kia Forte...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Kubota HB84 (A53317)
