OP
HawaiinFarmer
- Joined
- Dec 20, 2009
- Messages
- 9
What about crank? It looks perfect,the bearing for the piston was untouched. All other pistons are smooth as silk operating wise.
Straight, as in straight-as-a-arrow.i need some info on the push rods should they have a bend at the top or should they be straight?
Sorry for not responding...Holidays
Ok to make short and concise.
Took the oil pan off and sure enough a bent piston arm on the # 1 cylinder.
Secondly i need some info on the push rods should they have a bend at the top or should they be straight? all have a bend at the top but some look more or less than others. Looks like the compression might of bent the push rods.
Cylinder and bearing looks good so am I able to replace the piston and piston arm or do a I need to resurface the cylinder chamber?
Sincerely,
Destined to be a Kubota master mechanic...(like it or not)
P.S I'll be ready for the next guy who rolls his 5038
Can somebody explain how the liquid got above the piston? I can't imagine that coolant would get there, or fuel (the injected amount is small and would get burned/expelled at every revolution). So what is left is oil. In order to hydro lock the amount of liquid has to be quite large and enter the combustion chamber within one revolution. I am thinking that if it would enter the combustion chamber in small amount it will be blown out before it could lock the cylinder.
I can imagine that even if the combustion chamber is half full that it will increase compression pressure that could possibly cause engine damage. So can somebody shed light on what was the sequence of events and the mechanism of getting liquid to the combustion chamber leading to engine damage?
