Root grapples
/ Root grapples #1
calhoun9001
Michigan
2014 John deere 5085e
Looking for opinions on a good grapple for my 85e. Has the 260 loader on it. Will be using it to move cut brush, move firewood and clear over grown areas. Been looking at them at everything attachments. Really like the extreme duty root grapple, any thoughts?
/ Root grapples #2
I have an 7' model from Loflin. Been working it pretty hard for at least 10 years now with most of it's "time" on a large skid steer. Loflin Fabrication I would recommend it.
/ Root grapples #4
Go onto eBay and type in Faver Grapple. Note how Faver is spelled. Lots of sizes at good prices.
/ Root grapples
Thanks for the input, I have the 260 loader on the 85e would you go with a 6 or 7'? Lift capacity on the loader is just under 4000lbs. Any idea what the Loflin weights? Couldnt find that on their site.
/ Root grapples #6
We have a Blue Diamond 84" grapple with approx. 40" opening. I like the over 10" wider opening that Xfaxman has and would have bought that one had I been aware of it. You would have no problems with a 7' grapple.
/ Root grapples #7
This is the 6' wide Monster Grapple, Shipping weight was listed at 1200 pounds.
The 6' will pick up as much brush as their 8' model. If you are working in the woods, get the 6'.
If you need to rake large areas, get the 7' or 8'. And with the big opening it does rake very well. :thumbsup:
The width of the grapple has no effect on picking up long items, since you need to be near the balance point so it doesn't twist the loader arms.
This grapple is 44" wide. Moved them to the brush pile with the top tines not clamped down.
Keep us "posted" on what you get.
/ Root grapples #8
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=362019"/>
I agree that a tall vertical opening is much, much better if you are moving any significant volume/size of debris. My L bottom has 46" of opening, much better than the 30" to 32" opening you see so often. Those are ankle biters, with calhoun's lift I would get a real grapple. As for width, wider is not necessarily better as xfaxman (guru of large grapples) says. If simply picking up logs or digging roots or rocks, narrow is better. If clearing a path into brush, make sure it is as wide as your outer tire dimension. If picking up loose light debris, wider is better. You get the point, I am sure.
/ Root grapples #9
From my limited experience with my Anbo GRM, I would say if you're wanting to pick up materials on the ground (Piles of fallen branches, etc) the bottom tines need to be fairly long. I have a root rake which I got explicitly for digging up roots and ground cover and it works great for that. But since the lower tines don't project out very far, they don't really pick up piles of stuff all that well. Which is fine for what I do, but if I were to spend most my time trying to pick up piles rather than dig, I'd make sure to get the longer lower tines.
/ Root grapples
Per your guys advice I went with the monster grapple 84". Tractor measures 78" wide so I thought the 84 would be my best bet. Plan on clearing overgrown areas and don't want anything left behind to get the tractor. Took Xfaxman advice and bought it through the guy on ebay. Seems like a real nice guy should have it next week. Post pics when I get it. Thanks again.
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A59228)
2025 BrushFox...
CAT CB34 (A60462)
CAT CB34 (A60462)
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
JOHN DEERE 5065E TRACTOR (A59823)
JOHN DEERE 5065E...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
