Mowing Rossi 5-foot Sickle on BX25 - Video Link
   / Rossi 5-foot Sickle on BX25 - Video Link #11
They maybe talking about the Float position. I think mine is the same. I have not tried it yet but it would allow your bucket to float with the ground undulations rather then dig in. Not sure if you want that when mowing?
   / Rossi 5-foot Sickle on BX25 - Video Link #12
Cause I forgot. But I'd never wear a seatbelt anyway when mowing around the pond. I have this fear of drowning and would want to eject myself from the tractor if it goes in. Usually I have the ROPS up and wear the seatbelt when on a slope.
Because one can forget to put up the tall ROPS I think the shorter fixed ones are still a better setup. I do like that they have gone wider so there is less chance of getting caught between the ROPS and the ground.
That is one sweet mower setup.
I am guessing that that pond does not have a liner. If it does someone did a nice job on the edge. I like it.
   / Rossi 5-foot Sickle on BX25 - Video Link #13
thanks for sharing...nice setup...
   / Rossi 5-foot Sickle on BX25 - Video Link #14
ok - I now have another question. Dont you find it a little difficult to disconnect under pressure when then FEL is up in the air? it must be harder to reconnect FEL hoses.
As for the way dealer suggested to be connected - david is right about float. If you push the FEL stick past detent - the sickle can now float in the lumpy conditions instead of locking and digging in. Give it a try - I think you will learn that its a nice feature. If you still want to lift/lower constantly, then feel free to swap the hoses so its more "natural" to you. it won't hurt a thing. Dealer suggested to leave it as is as it the float feature you most likely should use. Granted - you cant use float on pond edges, but in the fields its useful.
   / Rossi 5-foot Sickle on BX25 - Video Link #15
The cutter is nice by why is the ROPS down and no seatbelt ? No too safe IMO.
I was thinking the same thing, and then came the "pucker factor".
   / Rossi 5-foot Sickle on BX25 - Video Link #16
Safety is something we should never forget or we'd end up in the Safety forum, and that's NOT good.
   / Rossi 5-foot Sickle on BX25 - Video Link #17
Nice video and neat setup. I think the issue the dealer is referring to when he tried to hook it up so stick-right would move it down and stick-left would move it up is the regen. function. You can do a search here on what regen is but it's common to employ it in the FEL dump/curl circuit. As I understand it, with regen, hydraulic oil moves from one end of the cylinder to the other as you dump the bucket thereby giving you a more controlled dump. If you push the stick all the way right past the detent (which you should be able to feel), you'll go past the regen feature of the FEL valve to fast dump, where the hydraulic oil is sent back to the tank. I don't believe that is the same as float, which you only have on the boom/up-down circuit of your FEL.
But, you could use the FEL boom circuit with the float feature to run the sickle-bar mower. Might be intuitive since pushing the stick forward would drop the mower and pulling it back would raise it like you're use to with the FEL. If you could mount some sort of anti-scalp wheel on the end of the mower and put it in float, it might follow the ground contour nicely, except for mole mounds or the like.
Let us know how it works out after you've used it some more.
OK, here's what I think I know. :) If I move the curl control to the right past the detent position, the bucket tilts downward slowly and with enough force to raise the front end of the tractor. It's as the dealer said, it's a slow controlled dump. If I push the control forward past that detent position, the boom floats. I don't have a float feature for the curl, just the boom.
When I lower the bar it just takes the pressure off the bar lift cylinder and the bar lowers itself from a strong spring. It's what keeps the sickle in contact with the ground at all times, limited by how far the cylinder is extended. It's like the cylinder sets the lower limit and the spring allows the bar to ride over humps in the ground. At least that's how I understand it. And if I had level ground to mow that's probably how I would use it. As it is, if I did this around the ponds or down that hill, I'd be cutting into soil at times (a bad thing, like getting your chain saw into the dirt, right?) because the humps are often in the middle section of the bar where there is no skid.
And now, after using it to cut all around my ponds, I realize that cutting is the easy part of the story. Cleaning up the mess left behind is the other part and is why I can barely walk today. Back-breaking work to fish out all the stuff in the lake and rake up all the trash left behind. I wish it would cut, then mulch! Maybe I need another attachment to do the raking. And a bigger building to keep up with my attachment collection. Does it ever end???
   / Rossi 5-foot Sickle on BX25 - Video Link #19
The curl circuit has no float position. it has regen istead of float.
the boom is still connected so there is no pressure on the circuit.
I would be willing to bet the loader is still on the tractor as required ballast so disconnecting the boom would cause the difficulties mentioned above
regen works by making the bucket FAST DUMP. the way it works is when in regen hydraulic pressure is ported to BOTH sides of the cylinder. and between the bucket cylinders being unbalanced(more power/less speed one way and more speed but less power the other) and gravity it dumps fast and also keeps the floppy bucket syndrome from happening
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
New Wolverine Skid Steer Root Rake Bucket Attachment 31'' (A53002)
New Wolverine Skid...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
