Rotary Cutter Discharge
   / Rotary Cutter Discharge #1
Piperflyer
USA
Kubota3030HST
Do you recommend a side or rear discharge on a finish mower and why?
   / Rotary Cutter Discharge #2
I have never seen a rotary cutter with anything but a rear discharge. Are you possibly talking about a rear finish mower?:confused:
   / Rotary Cutter Discharge #3
I have a side discharge finish mower and wish I had gotten a rear discharge .. why ... I am not happy with the windrows it leaves ...
Leo
   / Rotary Cutter Discharge #4
Get a rear discharge. It's easier to cut up next to stuff. Rear discharge won't leave a windrow so much, but it will leave clumps of grass if it's real high and/or wet.
   / Rotary Cutter Discharge #7
There are plenty of side discharge rear mounted finish mowers and some folks like them. Not having tried one, I can't say, but I have had two rear discharge, rear mounted finish mowers and really like them. If the grass is high or wet as has been said clumps will remain. The rear safety chains on my bush hog model will sweep them up into piles as you drive. I have taken the chains off and also put gator mulching blades on and am quite happy with the result.
   / Rotary Cutter Discharge #8
my 72" MMM is a side discharge. the rear discharge decks are built a lot diffrent as to not haveing to toss all the clippings out the right side.
If i leave the discharge flap down, it windrows so bad it looks like ive raked it and am going to bail it.
IF i had to choose i would pick rear discharge.
nothing to add to my previous post... still feel the same way
   / Rotary Cutter Discharge #9
Rear discharge cause it can cut taller grass easier and better, also you can cut closer to trees, buildings...etc on both sides of cutter which reduces your cut time.
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2016 FORD FUSION SS (A60430)
2016 FORD FUSION...
