IH3444
Veteran Member
- Joined
- Jan 10, 2004
- Messages
- 2,116
HGM said:Is there something wrong with the Motorcraft 15-40 that was designed to run in the engine?
No, nothing at all wrong with the repackaged Ford 15w-40. Could be Rotella
IH3444 said:Is there something wrong with the Motorcraft 15-40 that was designed to run in the engine?
cp1969 said:Usually there will be a list of manufacturers whose specifications an oil meets on the back of the jug.
Is there a spec put out by Ford or IHC for their engines that Rotella does not meet?
I have read claims about the changeover with high miles on an engine causing seals to leak.GreatWhitehunter said:So are you telling me that if I change over to synthetic rotella I'm going to start having problems? I'd like to get alittle more mileage out of the oil before changing it. I certainly don't want to change oils and develop issues.
Matt T.![]()
rback33 said:Boy.. they are putting it to ya.... I change my own oil on most of my vehicles, but since the engine is still under warranty I am letting the dealers change it. Even then I only get hit for 65-75 dollars for it. I also specify Rotella. I probably got a great deal on my last service...did the engine & tranny both with both filters and an air filter... for $262 felt like I came out OK on that... Coulda done it all myself, but the dodge tranny scares me a bit from the horror stories I hear.. so I baby it some and let the pros mess with it.
Matt T.![]()
