rotella T better than valvolene?
   / rotella T better than valvolene? #41
_RaT_ said:
Oh boy, I know where this can lead. GSXR1100 where are you. :D
_RaT_, don't you know you are not supposed to mention You Know Who's name? :D:eek:
Later,
Dan
   / rotella T better than valvolene? #42
Soundguy said:
I knew I was getting the designation for S & C wrong.. but I did know s was for gas and C was for diesel at least.. that get me anything??
While you may be "wrong" we are in the same boat since I remember the S and C the same way as you do. It makes sense. Service and Commercial? What they heck does that mean? :D
You should get a Gold Star and the API should change the meaning to something meaningful. :):):)
Later,
Dan
   / rotella T better than valvolene? #43
I can't wait for winter to end
   / rotella T better than valvolene? #44
CJ4 said:
Soundguy,
I'm giving you a big round of applause and respect for knowing more than I did at least!!!! Now I know maybe I shouldn't use Rotella T in my gas engines huh???
Most if not all diesel engine rated oils are also multi spec'd as gas oil. Check the API logo the next time you get Rotella T. I think you will find that in addition to being CJ-4 rated it is also either SL or SM automotive rated.
   / rotella T better than valvolene? #45
Later,
Dan
I think the reasoning was that when API was originally formed most diesel engines were found in Commercial trucks. The S for Service, if the rusty memory serves correct it meant it was to be used as a Service fill for gas engines. :rolleyes: :) I agree the S for Spark ignition and C for Compression ignition would be much easier to remember.
   / rotella T better than valvolene? #46
CJ4 said:
Soundguy,
I use Dello 400 in my gas engines.....
   / rotella T better than valvolene? #47
I agree.
Rotella & walmart full synthetic are in the same group, III.
   / rotella T better than valvolene? #49
Shell Rotella® T Synthetic SAE 5W-40 is a fully synthetic heavy-duty diesel and gasoline engine oil developed especially to meet the requirements of North American driving. The exclusive Shell formulation offers users exceptional performance and protection in combination with enhanced fuel economy potential over conventional 15W-40 motor oils. This synthetic multigrade engine oil meets the service requirements of virtually all four cycle diesel and many gasoline engine manufacturers. Applications • Recommended for new and older diesel- and gasoline-powered vehicles, including personal vehicles and commercial vehicles such as on-road, off-the-road, truck rental, pickups, delivery, utility, and school bus fleets • Meets or exceeds the diesel engine requirements of API CI-4 PLUS, Cummins CES 20078, Detroit Diesel, John Deere, Dodge, Ford, GM, International, Mack EO-N Premium Plus 03, Volvo and others; For gasoline engines, it exceeds API SL.
I pasted this from Shell PDF file. Everyone do your own research, and choose what your manufacturer recommends, and you won't go to far afield.
Why not? It carries a good S rating as well??
Soundguy
CJ4 said:
Soundgu
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
