Round Bale Unroller
/ Round Bale Unroller #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
Has anybody tried one of these bale unrollers?
I guess it would be good for spreading hay out for the cows or maybe unrolling bales so you can rebale into squares or something.
Comments?
D.
/ Round Bale Unroller #2
What kind of bale unroller? We had a DewEze Superslicer that we fed 500 cows through the winter with, worked great. Also had a 3 point unroller that pulled the bale along the ground, unrolling as it went. Worked pretty well as long as you where pulling the bale the right way.
/ Round Bale Unroller #3
My B-I-L unrolls his bales with his tractor. Raises it up on the FEL, picks up a little speed, dumps it, slows down and lets it roll. If it doesn't completely unroll he then pushes it along with the front tire. Looks kind of dangerous to me but it works great.
Sometimes he also carries them in the back of his AM General pick up and we push them out the back on a hill and just let it unroll down the hill.
Low tech but effective.
My mistake: the frontier at
John Deere: Features for 3PT Bale Unroller
Model: BU1059
2"x8" Hydraulic Cylinder Activates Arms from Comfort of Operator's Seat
I & II Match (iMatch & Quick Coupler - II & 3N)
Handles One Large Round Bale
D.
/ Round Bale Unroller #5
Model: BU1059
D.
I never understood what kept the bale from just rolling along on the ground?
/ Round Bale Unroller #6
Model: BU1059
D.
Very similar to the one we built when I was growing up, works pretty well. Downside for feeding cows it it makes a 4-6 foot wide (width of the bale) line of hay, so cows will step on hay to get to the middle, wasting some. The Dew Eze super slicer works better in that regard. For spreading bedding, one like the Frontier would work great.
/ Round Bale Unroller #7
Comments?
D.
For conversion of round to square bales...there is only one unit out there...:D
T's Easy Unroller
/ Round Bale Unroller #9
ddivinia said:
It is horribly expensive...
D.
This is for the commercial hayman...:)
If you read the studies that were done...The money made on selling squares vs rounds...there is indeed PROFIT...:D
/ Round Bale Unroller #10
I used a 3 point hitch unroller [round bale] works good , they need a stop or brake so they don't spend around when you pick the bale up you have to catch in the center both backward and up and down which is hard to do every time exactly in middle with a brake or stop there would no problem. I like to go around hills instead of up and down.
/ Round Bale Unroller #11
Comments?
D.
I use a RW bale spinner to feed round bales. You can spin the bale in either direction to unroll it andit leves the hay in a kind of a narrow wind row.They're made by Worksaver.
JLG E300AJP TELESCOPIC/SCISSORING BOOM LIFT (A60429)
JLG E300AJP...
UNUSED IRANCH MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED IRANCH MINI...
FARMHAND 827 FEED MILL (A60430)
FARMHAND 827 FEED...
HYUNDAI HL730-7A WHEEL LOADER (A60429)
HYUNDAI HL730-7A...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
24in pin on tooth excavator bucket (A61306)
24in pin on tooth...
