Round posts & attaching girts
   / Round posts & attaching girts #1
opalko
Mississippi
1949 Ford 8N,2014 Kubota L3301
I have finally started work on a small (16x30) tractor & implement shed, single pitch shed roof. This will be made with post & beam construction but with round poles (they were free). My question for you all is what is the best method to attach the top plates / girts to these round poles. I have seen pictures of circular nailing spike grids in pole barn construction books (like these), but my local building supply places have never heard of them..! What is the next best way? I have also seen pictures of people using a chainsaw to notch out a place for the girts but it would appear if you did this on the top of the pole, and on both sides, it would significantly weaken the pole...? Lag bolts? Carriage bolts?
Thanks for ideas & help.
Robert
   / Round posts & attaching girts #2
I would use pole barn nails for the girts, predrill the girts to make it easier to get nails headed right direction. If you have a palm nailer they're handy for pole barn nails unless you're a gorilla and can really swing a hammer.
When you say top plate, I assume you mean the headers that carry the trusses. I would notch the pole to the depth of one of the headers, presumably it's a double header so that means one of the headers would extend beyond the face of the pole. I'd fabricate the double header before you set it up there, then use a through bolt to hold the header to pole. You can also put a cleat under the header that extends past the face of the pole so it's supported by the cleat. Then use a bunch of nails or bolts to hold the cleat to pole. I agree with you that I would not put any notches in the pole other than at the top.
   / Round posts & attaching girts #3
Just like BeezFun says, that's how i've done a few, except didn't have the palm nailer back in the day, so it was swing like a gorilla! :) The girts are really just to hang the siding and help hold the post into position, square etc, but the headers at the top of the poles hold the weight of the roof structure and any live load. Bolt and cleat the headers and if you like liquidnails go head i've used it but i think it's over kill.
First time i used my palm nailer, i was kinda upset with myself for not getting one sooner. Not only is it easier, it's easier to be accurate.
I guess what I'm referring to the top plate is the double girt that the rafter sits on. My shed will be a single slop shed (lean-to) roof. Do I still need to notch it at the top?
   / Round posts & attaching girts #5
Ive notched round poles for girts with a chain saw and chisel. That works but i like sawing a flat on the length of them. Last batch I called a guy with a portable sawmill. I loaded the poles and traveled to him. We sawed 30 poles in a hour and he charged me 100 bucks. It was worth every cent.
   / Round posts & attaching girts #6
If you choose the pole barn nails, or lag screws, do predrill for the lags. And, for both put a dab of bee's wax on the tip of the nail or end of the threads on the lag screw, you'll be amazed how much easier they will drive. Try several with, and without..., you'll definitely see the difference. I usually wear old jeans, or in cooler weather Bib's, 'cause there will be some get on the hammer head, and you need to swipe it on something to wipe it off, or the hammer will glance. Something I learned form my grandpa, who was a carpenter.
Bee's wax is cheap. Buy a toilet bowl ring, and you'll have enough for your project. I have several fiberglass handled hammers I use. I drill a hole in the handle end, approx. 3/8-7/16" X 2" deep. You can use a knife, or screwdriver to fill that hole with the wax, or the last few years I put a blob in an old ladle, heat with a propane torch to melt it. Put them hole up in a vise, and pour them full. I'm usually good for all day.
For lag screws, I'll melt a good bit more, and pour it in smaller prescription type bottles. Handy to carry in my Bib pockets, or nail apron, and not get all over everything.
   / Round posts & attaching girts #7
If you put one header on each side of the pole, and through bolt it, you don't need to notch if you don't want to. I feel more comfortable with two types of connections on the header, that's why I like a notch. I think you'll find it tough to use cleats without splitting them because of the curved pole surface, so maybe that's not well spent effort. If for some reason you need to attach both headers to the same side of the pole, I would not be comfortable without a notch because you are creating quite an offset load on whatever fastener you use.
   / Round posts & attaching girts #9
Yea you either can set the beam up top with a bracket or you really should notch the post and set the header into it.
Ok, how does it work if the total span, say 30', is longer than a single beam? Do I have 2 beams meet in the center of a post and still notch it to have 4 lag or carriage bolts go through the post? I wish I could see a picture of such a setup.
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
Forklift (A59228)
Forklift (A59228)
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
2023 Kubota L6060HST Compact Utility Tractor (A56436)
2023 Kubota...
2011 GMC DENALI HD PICKUP TRUCK (A59575)
2011 GMC DENALI HD...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
