RTV 500 Gas Cap?
   / RTV 500 Gas Cap? #1
DIXIEDOG
Platinum Member
Maine
International 2544 / Gator 825i/L2501/General
Can somebody check out the gas cap on their RTV 500 and tell me if it has a keeper on it? By keeper I mean a piece that hold the cap so you can just let it hang when you remove it. I could have sworn mine had one but when I added fuel it didn't so I'm thinking I might need to go on a fishing expedition to get that piece out of my tank. :eek:
   / RTV 500 Gas Cap? #2
Well 1.
Did you pull the "Keeper" out with the cap? Checked mine and it seems to be a pretty long piece of material that is connected to the restraint at the bottom of the fill tube.
If you did break it off, it is such a large piece that I would not worry about it as it is too big to cause a fuel restriction problem and interfere with the fuel pickup tube etc.
Later,
JW5875
   / RTV 500 Gas Cap? #3
I had a gas Kubota mower a few years ago. The rubber ring sealing the lid when the cap was screwed down was missing. I looked in the tank and it was laying on the ledge of the tank. It was really soft and gummy. I fished it out and told Barlows I needed another ring. They don't do just the ring so they gave me a new cap with ring.
Some months later I had a bad running Kubota. Looked at the opaque fuel filter and saw something black in it. Replaced filter and never another problem. Sure it was some of the dissolved rubber ring.
   / RTV 500 Gas Cap?
I definitely didn't pull the keeper out with the cap so I guess it's time to go fishing. I wasn't positive it had one but it sounds like it does.:ashamed:
   / RTV 500 Gas Cap?
I just checked mine, I have one.
That's what I thought, now I just got to figure out how to fish that sucker out of a 3" hole....I can pretend I'm ice fishing. :laughing:
   / RTV 500 Gas Cap? #7
I don't if there is an easy way to drain gas from the tank, probably is but I haven't looked. Once drained, shine a light in the tank and see if you can see it. Either way, a rod, coat hanger or something with balled up duct tape on the end should work to *stick" the keeper and pull it out.
   / RTV 500 Gas Cap? #8
I was able to look down mine and fish out the nozzle that slipped off the gas can with a piece of wire. Now I gotta check if my cap has the keeper.
24220 (A56859)
24220 (A56859)
2019 CHEVROLET SILVERADO 11FT FLATBED (A59575)
2019 CHEVROLET...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2020 WABASH DRY VAN (A59575)
2020 WABASH DRY...
