Rudd gas furnace- no HEAT - HELP
   / Rudd gas furnace- no HEAT - HELP #11
I keep reusing the same old peice of emory cloth on my flame sensor every winter. I just leave it lay there because I'll need it next year.
   / Rudd gas furnace- no HEAT - HELP #12
Not to cause a problem; but I always belived that emery paper left
a reidue on the surface. Could this maybe contribute to your yearly
clean up of your flame sensor? Steel wool might be a better choice.
Just trying to be helpful. I know it is no big deal to clean.
elad
Thanks for the replies , and offers of help. Update.
This unit does not have a Flame Sensor.
It appears the combustion chamber has cracks , therfore altering the internal pressures the gas valve senses, therfore will not stay lit....
Manufacturer no longer makes replacement combustion chambers.
Still exploring options.
   / Rudd gas furnace- no HEAT - HELP #14
:D:D I do the same thing. The emery cloth lays right on the side of furnace so I can use it when ever the furnace won't come on and stay on.
   / Rudd gas furnace- no HEAT - HELP #15
That doesn't sound good. I was told about 5 years ago that if the combustion chamber was cracked that they wasn't allowed by law to change it. I don't know it that was right or not. It was an old furnace that was having the problem, so I just went ahead and replaced it. Does anyone know if that is right or not?
Jerry G - Don't know if that is right or not - but I do know the manufacturers sell replacement chambers/parts.
Unit replaced - Ouch $$$$$
   / Rudd gas furnace- no HEAT - HELP #18
No that's not correct. I have replaced several cracked combustion chambers 1 cell at a time. as long as the manufactuer still makes the chamber they can be replaced You should have gotten another opinion
Dazed and Confused
Jerry G said "I was told about 5 years ago that if the combustion chamber was cracked that they wasn't allowed by law to change it."
I responded that the manufacturers make replacement combustion chambers , so I assume it is not unlawful to replace them !!!
I also followed up with a post that my decision was to replace my old furnance with a new furnace.
That decision was due to the fact that Rudd no longer makes the replacement combustion chamber for my unit , and that they actually had a recall on that series of furnaces (due to cracked combustion chambers) which I just found out about as a result of my unit's chamber cracking. Rudd offered me a $400 rebate to replace , so that is what I did.
All that to say I don't know if KenMac is talking to me or Jerry G ??
Either way no hard feelings , just did not want to leave anybody hanging !
That's the whole story and I'm sticking to it....
   / Rudd gas furnace- no HEAT - HELP #20
I was responding to jerry's post . Letting him know that the guy that told him it's against the law to replace a combustion chamber. Telling him to get another opinion. Would like to know who's law it's against as the manufactures do make replacement cells for furnaces
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
More info coming soon! (A53421)
More info coming...
2017 Freightliner MT55 Box Truck (A55788)
2017 Freightliner...
2014 INTERNATIONAL 4300 18' REEFER BOX TRUCK (A54607)
2014 INTERNATIONAL...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
