running high gpm attachments out front?
   / running high gpm attachments out front? #41
The 3pt is 5K and the PTO system is over 5K. Then you gotta remove front axle, cut frame and remove front of engine clip on tractor to install it. :laughing:
Still a lot cheaper than buying a used skid steer.
Yeah, the old ford's like the 5000 was built for things like that. It already had the mounting holes for the shaft and the pulley on the crankshaft was even made to have things bolted right to it so it didn't even need replacing. I guess that's why you see so many of them that have boom mowers with them front mounted hydraulic pumps.
Kubota B2301 (A53317)
208789 (A60430)
208789 (A60430)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2018 John Deere Z997R (A53317)
2018 John Deere...
