Running Hot
/ Running Hot #1
sox3
Newark, de
International 424
Hi all,
New member here.
I have an International 424 Gas which I have recored the radiator, new cap, water pump, etc.
The tractor runs hot as the temp gauge shows 250 260 degrees but when I check the temp
at the thermostat housing it shows 230 or so. Thermostat is a 170. Possible blockage in block
or head? Any help appreciated.
/ Running Hot #2
Hi all,
New member here.
Have you checked your thermostat?
/ Running Hot
its a new one. 170 degree
/ Running Hot #4
Even new thermostats can be bad not often but it happens Maybe gauge is off? Good luck.:thumbsup:
/ Running Hot #5
Check temp of block with non-contact thermometer. If gauge is correct you have either a water flow or an air flow problem. Back wash the radiator fins with engine cold. Start tractor with rad. cap loose and check water flow when engine temp over 180-190F. Show be more water flow than a garden hose would produce. If water flow seems slow look for blockage.
/ Running Hot
Radiator has been recored. I check the temp at the thermostat housing with inferred temp gauge and it s
running 230 or so. Gauge showes 250-260. Fins are clean as core is new, plenty of air flow. How do I go about
looking for a blockage in the block or head?
/ Running Hot #7
Are you sure the water pump belt is tight, the lower hose is not collapsing as the engine speeds up and the pressure cap is the correct rating and is working properly? Make sure the timing is correct and the advance is working correctly. A retarded spark can cause the engine to run hotter. So can too lean a mixture, due to reduced charge cooling.
If the infra-red shows 230F at the thermostat housing and gauge shows 250-260 and the sending unit is near the thermostat housing I'd susupect the sending unit or the gauge. If you can find a spec on the sending unit you can measure the resistance and see how it compares to the spec. One way to check the gauge is to hold the wire that connects to the sending unit to ground momentarily. The gauge should peg out to max temp. If it does the gauge is good and the sending unit is the problem.
/ Running Hot #8
Regardless of the somewhat innacurate gauge, 230 is too hot. Your water pump could be faulty (worn or rusted up impeller), or have an obstruction in the block. Have you tried a can of cooling system cleaner? You put it in, run it for 30 or so minutes, and then drain/flush the system. If the problem is a chunk of rust clogging up cooling somewhere it will help with that, and will clean out biological crud also. If you are sure about the radiator, and there isn't crud in it, and once you clean the system and check out the water pump, then it's time to take the head of and get it serviced. Servicing should include hot tanking and furnace baking to clean out the water passages, plus whatever needs to be done to service the valves.
/ Running Hot
Thanks for the reply, Belt is tight, cap is correct new 7 lb, pump is new, hose not collapsing, sending unit in thermostat housing, havent checked timing
but will do. I think there is a flow issue in the block. It is boiling at those temps and lifting the cap. I also have the correct amount of antifreeze in it.
I'm thinking about pulling the freeze plugs and see whats in the block passages. When I replaced the pump I did not see any debris in the upper areas,
but the old radiator core was severly plugged up.
/ Running Hot
Update:
Pulled 2 freeze plugs, looks good inside block. Today I pulled the head, small
passages were clogged and I was able to clean them out. Just waiting on
a new head gasket and see how it does then.
/ Running Hot #11
can always back flush and then flow test it too.
ditto on the non contact thermometer too
/ Running Hot #12
If you took the head off, did you pop the water pump off and take a look at that also?
/ Running Hot #14
I was betting on a bad head gasket after all the new parts you have already tried , but now you have pulled the head and will fix it when rebuilding after inspection , change the thermostat again anyway they are cheap !
/ Running Hot #15
The best test would have been while it was still together. I would have suggested a cooling system pressure test. You can usually rent the tool for this from AutoZone. It pressurizes the system so you can get a good idea of where the issue is coming from.
/ Running Hot
I did a pressure test on the system to look for leaks. How would that tell me where the problem is?
/ Running Hot #17
If it held pressure, then there's no leak. Maybe the engine was running lean (which can cause the same problems...and yes, I forgot if it was gas or diesel). If it didn't, it's easier to listen, etc for a leak when an engine isn't running.
/ Running Hot
Gas Engine, No leaks, not running lean. new gasket here Monday and will reasemble. cleaned out block and head
water ports.
/ Running Hot #19
when you changed the thermostat are your sure it's in right ? many a good mechanic has made a simple mistake like installing upside down and run into the same problems you have !:2cents:
/ Running Hot
Yes it was in right and you can tell when it opens.
UNUSED REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED REMOTE...
2019 F-550 Bucket Truck (A63118)
2019 F-550 Bucket...
2008 New Holland T2420 (A60462)
2008 New Holland...
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
2016 CATERPILLAR 299D2 SKID STEER (A62129)
2016 CATERPILLAR...
Woods HS106 Ditch Bank Mower (A63116)
Woods HS106 Ditch...
