correct. you are wrong.
3pt on 1953 on the model JD 40. Had live hydraulics too which the Ford still lacked.
Bzzt. sorry.. wrong answer. still suffering from a lack of not knowing what you are talking about I see. Late in 52 witht he NAA model, ford had live hyds via an engine mounted pump.
all fords left the factory with brakes.
as i stated.. the 8n had provision for a swinging drawbar. since this thread was specifically asking about an -8N- I figure that's appropriate.
in late 52 with the NAA, top hyd cover was made with provision for an aux hyd scv.. you were compairing this witht he 40 in 53 earlier.. right?
The early N's did not have a factory drawbar and instead used the 3pt.
the 9n / 2n did not have provision for a swinging drawbar unless you swapped out the 100% compatible 8n center section.. however as stated.. this thread was specifically about an 8n.. it DID have the provision for a swinging drawbar.
Only a 3 speed trans with ta too fast 1st.
3 or 6 or 9 forward gears, depending on if you added an optional over, under, or combo trans... in late 47 that changed to a base 4 spd, and still the optional over, under and combo, for even more speeds.
Hence the rash of squashed Ford operators found under N series Fords.
that's a lack of education on the operator.. not based on what brand / cole tractor he operated. pulling from above the plane of the rear axle is dangerous. pulling from below the palne of the rear axle is much safer. an unsafe driver can kill himself on any color tractor.. thus that point is moot.
Where is Ford today anyways ???
Legacy product of CNH.
Turns out ford made such a good machine, that is still being widely used soo much that they lost out on resales. lets face it.. if your machines you produced inthe 50's and the 60's and the 70's are still in WIDE use.. you have limited your future sales market. they may have been some of the cheaper machines on the market.. but they are also very durable.. as evidenced by the many still in use today. you may see lots of shiney green ones in parades.. but you see lots of rusty red/grey or blue/grey ones in fields working.. that says alot.
