Rustoleum implement paint mix ratio?
   / Rustoleum implement paint mix ratio? #11
mineral spirits cut half and half let cure 12 hrs and add another coat. You can do this as many times as you want . A little wet sand between coats will get you a glossy finish and cut down on orange peal . Thin coats is the key
   / Rustoleum implement paint mix ratio? #12
I have sprayed a lot of Rustoleum and have found that thinning with xylene works the best for large sections and panels, it drys a bit slower than acetone but much faster than mineral spirits. If you want a glossy finish thin as little as possible, I usually thin about 20% max.
   / Rustoleum implement paint mix ratio? #13
I just sprayed my metal barn roof using Rustoleum Hunter/Forrest Green and used a little less Acetone than recommended. As long as it sprayed well I was happy, and it turned out great with one coat.
   / Rustoleum implement paint mix ratio? #14
Well I sprayed the top today. Overall it went OK. I thinned it according to their website to about 15% and then I added about a third of an ounce of hardener. I made 10 oz of paint at a time. It's not a real glossy finish, I couldn't seem to get a wet look. I don't know if it was today's weather or what.
Did you wait the FULL amount of time required by the hardener to activate??
The wait is a killer, I know, you are ready to paint, and you have to sit around waiting for 30 minutes,,,
The second pic is Majic paint,,
The activated hardener will greatly enhance the gloss,,,
   / Rustoleum implement paint mix ratio? #15
I sprayed my winch with the Magic paint a month or so back and had no trouble getting that glossy.
Maybe the acetone? and the weather?
It almost looks like a matte finish.
I spray a lot of Rustoleum and that's what not enough thinner looks like. Paint is too thick. You have to add more thinner than you think. That's what works for me and your mileage may vary. Maybe try some sample panels.
Well I guess I will have to live with it the way it is. Next time I'll know to thin it more. Thanks all.
David
   / Rustoleum implement paint mix ratio? #17
David
If that were me I would just mix more and spray over that. I've done it before. What does everyone else think?
I may just do that. I have some and I can thin it more. I'll keep ya posted.
   / Rustoleum implement paint mix ratio? #19
An old painters trick was to spray thinner over the last coat B4 it totally hardened.
I tried it and yes it works as often if the paint was rather fumed or oversprayed.
It kind of dissolves the partially dried fumed paint and flows it to a glossy finish.
Not the perfect method but one way of saving a finish.
   / Rustoleum implement paint mix ratio? #20
As stated, Xylene is a good reducer for industrial enamel, (Rustoleum).
Just about anything will work to thin industrial enamel. But, you can lose gloss, if you use a lot of reducer, and or, pile on the coats.
Industrial enamel is the cheapest paint you can buy, they use very low quality solvents. It takes a long time for those solvents to evaporate. Paint doesn't "cure", (reach full hardness), until all the solvents are out of it. Putting your stuff out in the sun will help greatly, as the heat will help drive out those solvents.
Adding the correct amount of hardener, can help speed up the process. Keep in mind, more is not better. Adding too much hardener, will cause problems.
I suggest thinning as little as necessary to get the paint to spray nicely, with your equipment. This is almost always a good rule of thumb with any paint.
Secondly, allow each coat to "flash", (dry until it starts to get tacky), so as not to trap excessive of solvents in the film. Piling on the paint, will usually cause solvents to get trapped, loss of gloss, and slow down curing.
Apply enough paint, but more than two or three good coats, can cause trapped solvents. Excessive film build is also not better.
Use the proper protective equipment. Including, at minimum a charcoal filter respirator, when spraying industrial enamel. Disposable respirators only sell for around $25. And, if kept in an air tight container, will last about 40 hours of use.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
1996 John Deere 770 Tractor w/ backhoe
1996 John Deere...
2016 CATERPILLAR 330FL EXCAVATOR (A60429)
2016 CATERPILLAR...
iDrive TDS-2010H...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
