S15 (ULSD), S500 (LSD) and S5000 diesel fuel
   / S15 (ULSD), S500 (LSD) and S5000 diesel fuel #31
</font><font color="blue" class="small">( The transition to Ultra Low Sulfur Diesel (ULSD) fuel started in the United States on June 1, 2006 )</font>
nope, started before that, i know that 3 months ago we got our first load of diesel that was ulsd, they said that it only takes a few gallons to contaminate an entire tractor trailer load so they had to start before it was required so it would be all flushed out by then
   / S15 (ULSD), S500 (LSD) and S5000 diesel fuel #32
   / S15 (ULSD), S500 (LSD) and S5000 diesel fuel #33
It would be very difficult to dillute the high sulfur crud down with enough ULSD to get it all legal from the previous contamination. /forums/images/graemlins/blush.gif
   / S15 (ULSD), S500 (LSD) and S5000 diesel fuel #34
Thanks!
   / S15 (ULSD), S500 (LSD) and S5000 diesel fuel #35
last thursday i went to a short seminar on the ultra low sulfer diesel and they said that all it takes is 3 gallons of regular low sulfer diesel to make an entire trailer load,7,500 gallons, no longer meet the ultra low sulfer limit. at work our onsite fuel tank is 10,000 gallons and we started gettin ulsd about 3 loads back so they are figuring with the volume of fuel we use that it will be flushed out by the time its required. interestingly they said too that the new stuff has less btus per gallon so thus a loss in fuel milage will be expected. and lubricity problems are expected, they have tests that show it has less lubricity and there are companies that make lubricity additives to take care of this. only positive seems to be that it actualy has a slightly lower gelling point they say.
   / S15 (ULSD), S500 (LSD) and S5000 diesel fuel #36
Of course, the main positive of ULSD is that there is 95% less sulfur.
There is 1% less BTUs simiply because the higher molecular weight aromatic hydrocarbons have been reduced by being broken down into more paraffins, which is also great because aromatics are low in cetane value anyways and removing them raises the cetane level.
There is no problem at all with the lubricity of ULSD either, it's added at the refinery to replace the polar hydrocarbons that were broken down during the extra hydrogenation. ASTM specs the lubricity specifically for ULSD.
A total WIN-WIN situation for everyone that isn't worried about where all their stinkin' sulfur went.....LOL
LBrown59 said:
why so many duplicated post?
If you were around when the upgrade happened you would have seen Muhammad's explanation. He indicated that the dups would eventually be removed.
   / S15 (ULSD), S500 (LSD) and S5000 diesel fuel #40
I think my computer was down about that time so i must have missed that.
Thanks for the info!
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
2018 Kubota...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
