Safety glasses
   / Safety glasses #1
Dwellonroof
Batavia, Ohio
John Deere 3046r
Now that I'm getting older it seems to bother me more from the grass and dust while mowing, what is a good pair of tight fitting safety glasses maybe even bifocal but I need a tighter fit because the fine particles seem to get behind regular safety glasses.
Also I started to wear one of those cloth mask I purchased from Lowes a couple years ago.
   / Safety glasses #2
Only problem I can see you having with tight glasses is fogging up. I know what you mean tho re the dust...........Mike
   / Safety glasses #3
Google foam seal safety glasses or tight sealing safety glasses. There are some that are like a small giggle which I think are too bulky. There are others that look like glasses that have foam around the lenses that seal nicely. I wear this type when mowing. I think I got mine at Family Farm and Home but a lot of lawn and garden shops have them.
   / Safety glasses #5
We were issued these (the google toward the bottom)-
https://www.esseyepro.com/uploads/files/ESSCatalogWeb2019.pdf
But some of the guys gravitated to this style-
3M Maxim Safety Goggle 2x2 - Clear Anti-Fog Lens, Black Frame, Elastic Strap
This is an interesting discussion. A lot of welding shops require two forms of eye safety when grinding etc. So folks would wear their normal safety glasses and then would use a flip up face shield when grinding. That may be an option too.
Uvex Bionic Face Shield with Clear Polycarbonate Visor and Anti-Fog/Hard Coat (S8510) https://www.amazon.com/dp/B001VY3ACE/ref=cm_sw_r_cp_api_i_s8kQCbCAYSZ7Q
   / Safety glasses #6
... it seems to bother me more from the grass and dust while mowing,
When I bought my zero turn, it was horrible mowing through dry dusty areas. The amount of debris that would blow out from the front of my deck would make such a thick cloud that I couldn't breath or see. I did not know at the time that there was an adjustable piece of metal under the deck that I could lower to stop this from happening and only discovered it after changing blades and scraping the underside of my deck clean. I also learned that high lift, mulching blades made this worse then the factory blades. Since adjusting those two issues, I don't have any problems at all with dust blowing into my face.
   / Safety glasses #7
The local farm store chain in this area sells carhart safety glasses with a bit of foam around the lenses. I use them quite a bit while mowing and working in the shop, I do use anti fogging wipes on them as needed. As I recall, they were about $15
   / Safety glasses
Most of my dirt and dust seems to be when I turn and go the opposite direction, only a little breeze to make it blow back in my face. when it is damp I don't have the problem but I don't like to mow then.
   / Safety glasses #10
A possibility would be to investigate motorcycle glasses/sunglasses (called sunnies down here).
A set that I wore during my 'riding days' was made by "Wicked Fish"... included a foam-padded, detachable, inner thingy that essentially made them into goggles that could be worn inside your helmet.
Very fashionable.
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
2016 F-550 Stake Body 12FT Flatbed Truck (A50323)
2016 F-550 Stake...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
2010 Kubota L3400 (A50120)
2010 Kubota L3400...
